Results 1 to 10 of 10
Thread: salt issues
    Jun 2015
    vancouver canada
    4
    salt issues
    My pool is 15 years old. Every season I add approx. 500 lbs of salt to raise my salt level to 4500 ppm. This year i have had to add 1200 lbs of salt to attain 4500 ppm. I used Sifto pool salt for this. Now my pool is extremely salty and just not as pleasant to be in. Is it possible to get bad salt? Any ideas would appreciated.
    inground 100000 liters [25000 gals]. Saltwater with ecomatic chlorine generator. Attached hot tub. Vinyl liner. Haywood h series boiler. Haywood 1 hp pump.
    30,402
    Re: salt issues
    Welcome to the forum.
    Anything is possible, of course. Bad Salt? pretty unlikely.
    Most SWG's here in the states operate just fine at lowers levels (3000) than yours.
    Is there a reason you are running at 4500?
    38,237
    Re: salt issues
    How were getting your salt levels? I hope from a independent test and not trusting the SWG reading.
    When a SWG starts to fail it usually reads a salt level lower than reality. I am guessing that is why you have now likely added way too much salt.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: salt issues
    it sounds like from what you normally add your at about 8000 to 10000 ppm salt, you need to test it with this kit..
    TFTestkits.net
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    Re: salt issues
    I'm with the others here thinking the OP I getting false low readings from the SWCG. I think the fact that the OP reports the pool is now very salty and unpleasant pretty much confirms the actual salt level is way too high now.
    Unless you're replacing all the water in your pool every season there's no way you would need to add 500lbs + every season to a 25k gal pool.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jun 2015
    vancouver canada
    4
    Re: salt issues
    Thank you for replying. My Chlorinator requires a minimum of 4000 ppm. I will take a sample to get it tested to see if i am too high.
    Jun 2015
    vancouver canada
    4
    Re: salt issues
    Thankyou. We have a very high rainfall here causing major pool overflow and of course chemical and salt loss. Yes 500lbs certainly sounds like a lot but that amount has consistently given me excellent results over the past decade. Suddenly I'm up to 1200 lbs! Going to get another check.
    I don't have a salt reading on my Chlorinator. My levels are from indepenent testing. Will get testing done elsewhere. Thanks
    38,237
    Re: salt issues
    You should be using PoolMath to calculate additions, not just guessing.
    According to that, for 25k pool, 1200 pounds has added 5700ppm of salt. That is chemistry, not guessing. So, yeah, it is way too high.
    500 pounds adds about 2400ppm of salt.
    Jun 2015
    vancouver canada
    4
    Re: salt issues
    Every season I have my water checked for salt ppm by a pool co. and consistently they have recommended approx. 500 lbs of salt. This year my ppm would not come up. In the end it would appear that their equipment was failing or operator error. That's the only thing I can think of. Anyway on a retest with different co. my ppm is way over 5500. The co. is coming over to assess. Thanks.
    38,237
    Re: salt issues
    This is why we recommend testing for yourself and not trusting pool stores.
