Results 1 to 14 of 14
Thread: Asking for help on how to clear pool water
    May 2015
    London, Ontario, Canada
    6
    Hi All,
    This is my second question as a 25,000 gallon pool owner, the first was regarding my pool setup, specifically how to remove water from the pool (turns out the handle to the ball valve had been broken off).
    Now, I'm asking for help on how to get the pool looking nice and clear. The prior owners to the house (we moved in this past fall) had the pool looking in slightly better shape than us, so I know it's possible! I've seen posts on here recommending a home testing kit, but as we are brand new we've been taking water samples to a nearby store for testing and assistance. It'd been a month since the pool was opened and now we're getting anxious to be back in it, so I'm looking for additional insight/opinions, etc.
    So, I've listed below the water tests which we've done, along with what was recommended to improve the situation at each water test. As we're new, we did what was recommended to us. The pool has seen some improvement, but now is in a state where we can see the shallow end, part of the middle and none of the deep end due to the cloudy nature of the water.
    Over the past month we have used vacuum fairly frequently and cleaned the cartridge filter twice (once being two days ago, the second being a week before that).
    Pool Opened - May 27
    Heater turned on - May 29
    We don't have an automatic chlorinator, so we stuck two pucks in a floating dispenser in the pool.
    First water test June 6 after the pool had turned on us
    Free Chlorine - 0.02 ppm
    Total Chlorine - 0.22 ppm
    Combined Chlorine - 0.2 ppm
    pH - 8
    Hardness - 85 ppm
    Alkalinity - 65 ppm
    Cyanuric Acid - 1 ppm
    Copper - 0.1 ppm
    Iron - 0.4 ppm
    Steps taken - Shock pool, Algaecide, liquid chlorine.
    Second water test June 11
    Free Chlorine - 0.04 ppm
    Total Chlorine - 0.15 ppm
    Combined Chlorine - 0.11 ppm
    pH - 7.8
    Hardness - 87 ppm
    Alkalinity - 67 ppm
    Copper - 0.1 ppm
    Iron - 0.6 ppm
    Borate - 2 ppm
    Phosphate - 100 ppb
    Steps taken - a jug of stabilizer, 24 hours later a jug of liquid chlorine.
    Third water test June 13
    Free Chlorine - 0.73 ppm
    Total Chlorine - 1.18 ppm
    Combined Chlorine - 0.45 ppm
    pH - 7.8
    Hardness - 89 ppm
    Alkalinity - 87 ppm
    Copper - 0 ppm
    Iron - 0.1 ppm
    Borate - 3 ppm
    Phosphate - 100 ppb
    Steps taken - a jug of alkalinity increaser, a jug of calcium hardness increaser, two tubs of borate
    Fourth water test June 18
    Free Chlorine - 0.05 ppm
    Total Chlorine - 0.36 ppm
    Combined Chlorine - 0.31 ppm
    pH - 8.1
    Hardness - 120 ppm
    Alkalinity - 105 ppm
    Cyanuric Acid - 2 ppm
    Copper - 0 ppm
    Iron - 0.2 ppm
    Borate - 13 ppm
    Phosphate - 100 ppb
    Steps taken - a jug of alkalinity increaser, a jug of calcium hardness increaser, fill up floating chlorine dispenser with pucks - something like 5 or 6 in total
    That's where we are now and more than happy to hear anyone's thoughts/opinions/suggestions/etc.
    Thanks to all in advance!
    Jun 2014
    15,221
    Re: Asking for help on how to clear pool water
    Welcome (again) to TFP. Well, let's help by addressing a few basic TFP fundementals:
    Golden rule - Avoid the pool store for testing, advice, or products. You simply won’t get the advice/service you deserve and you will waste money on products your pool doesn’t need. Do not add anything to your pool other than what is advocated by the TFP site or its experts. You’ll have a happier pool, spend less time maintaining your pool, and probably save some $$ in the process. The following are short articles from this site that you will see linked in my signature below: Pool School, Recommended Levels (for YOUR pool), PoolMath Calculator, SLAM, and the Chlorine/CYA Chart.
    The proper test kit (i.e. TF-100 – link below) is the foundation of your pool care. Why this kit? We've learned through personal experience that you cannot rely on pool store testing, test strips, or simple over-the-counter kits. They simply do not read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. If you do not have a TF-100 or Taylor K2006 test kit, it should be your #1 priority.
    Only with your own test results can we really help you accurately. Once you receive either your TF-100 or Taylor K2006 test kit, post the following: FC, CC, CYA, PH, TA, and CH. we'll be glad to assist.
    Since your water is already changing, start reading the "SLAM" link below. Also look at the Chlorine/CYA chart below as it will be one of your primary tools in pool care.
    Have a great day!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP!
    Please update your location (state/country) and add your pool info to your signature as shown here, Pool School - Getting Started Are you in London, England or London, Kentucky?
    Get one of the Recommended Test Kits, I use the TF100 from tftestkits.net.
    When you get it give us some test results and get ready to SLAM Your Pool.
    We have no trust in pool store tests or test strips. Might as well stick a finger in the pool and hold it up to the wind, the results would be just as inconsistent and save you a trip. The only thing worth noting about those test results is that there is virtually no chlorine in the pool every time. It is important to keep the chlorine level above the minimum level for your CYA level at ALL times for your pool to be properly sanitized and algae free. Chlorine CYA Chart
    Here are some of my fave Pool School articles in case you missed any of them.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals and how to add them.
    Use PoolMath to figure out how much to add.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hello Cluk,
    Belated welcome to TFP.
    If you want clear, clean and sanitary pool water, then its up to you to make it that way. The pool store as you mention, obviously is not getting it done.
    I would like to ask you to please fill out your profile. You will be asking questions and the type of pool you have, and the pool equipment MATTERS. We cant help without knowing stuff about your pool.
    The steps to keeping your pool clean and clear are:
    Stop going to the pool store. Dont go back.
    Get your own reliable test kit like the rest of us have. The TF100 is the best bang for the buck. TFTestkits.net
    Next, read up on the ABCs of of pool water chemistry so you know what FC, CC, pH etc means and which chemical to use to adjust it.
    If your water is cloudy, you may need to SLAM it, or you may be having precipitation issues. But there is no way to know without reliable tests.
    Pool School - SLAM - Shock Level And Maintain
    After you have a test kit, and have dealt with the cloudiness, then if you keep your pool in the recommended levels range, then you will be home free.
    The appropriate chlorine level depends on the CYA level, here is a chart for handy reference.
    Pool School - Chlorine / CYA Chart
    And so how do we know how much of something to add if the water parmaeters are off? Well, we use a handy little tool called pool math. Easy to use.
    http://www.troublefreepool.com/calc.html
    So, there you have it. Its simple. TFPC is a methodology of pool care and we only add into the water what the pool needs. Thats it.
    You will find that TFPC and the Pool Store method are not compatible. Our opinion of pool stores is that for the most part (not all), they are scoundrels of the lowest order.
    If you choose the TFPC method to care for your pool, you wont regret it. If you choose the pool store method, you and your wallet will both regret it.
    Divin Dave,
    DFW, TX
    24,509
    Just for fun I googled how many states have a city named London. I thought it would be more but it only appears to be eight. Although, Ohio has two cities named London, that must be confusing. Lots of states have cities named New London.
    Geography tangent over.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    First I have to ask, are we in London Ontario or London, UK? That will make a difference as to what test kits are available to you.
    I'm going to guess UK, so check out this thread regarding test kits on your side of the pond. Test kits in the UK
    Support the site
    May 2015
    6
    Quote Originally Posted by tim5055 View Post
    London, Ontario it is. Thanks all for your feedback, will look into the testing kit and cycle back!
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by cluk View Post
    I am glad I didn't put any money on that bet!
    Support the site
    May 2015
    6
    Lol, and testing to make sure my signature shows.
    25,000 gallon, in ground vinyl pool.
    Equipment consists of a STA-rite System 3 Catridge filter, heater and pump.
    DFW, TX
    24,509
    Dang it! My money was on London, KY! The only test kit you can get in Canada is the Taylor K2006.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    459
    Get the K2006 test kit and order the BIG bottles of R-0871, R-0004, R-0013, also order another R-0870... you're going to need them, and don't want to run out in the middle of a SLAM.
    Welcome to TFP.
    I miss Ontario... I moved here from Kitchener.
    These people will hold your hand, and walk you through what needs to be done to get your pool PERFECT.
    As stated already... stay OUT of the pool store, you don't need them.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2015
    6
    Pool serviced - any idea what this is?
    Hi All,
    So while I'm waiting for my test kit, my wife and I decided to get the company that opened our pool to monitor the chemicals and get things back on the right track. They came today while I was at work and placed a bag of something (photo attached) in the deep end.
    We tried calling the company, but they said we'd have to wait until tomorrow/next day for the paperwork to be submitted before they tell us what was done to the pool. So this post is me just being impatient and trying to understand what is being done. If anyone is able to provide insight, I'd appreciate it.
    Thanks in advance!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Pool serviced - any idea what this is?
    My guess is it may be stablizer to raise CYA
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2014
    Franklin, NC
    9,193
    I would also guess CYA, but until I had MY test kit and determined I needed it I would remove it. You can just keep it in a bucket of water until you determine:
    1. What it is
    2. Do you really need it?
    Support the site
