Thread: Cygnet 2 motor removal
    Jun 2015
    Tamaqua pa
    2
    Hello i am new new around here and am naturally in a bind for info. I have a jacuzzi cygnet 2 pump with a 1.5 hp 56y frame motor that just died. I have a new replacement motor but am have not been able to remove the existing motor from the pump housing. The 4 through bolts have been removed and the motor now spins but I can't get it released from the pump section. Judging but the pics from a parts breakdown I found it looks like it should just separate at a plate with a large o ring. Is anyone able to steer me in the right direction? Thank you for any help, john
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Cygnet 2 motor removal
    From the pics and diagrams I can find it looks like those 4 bolts should be all that holds it together. The o-ring is probably just stuck to both halves, holding it together. Rock the motor up and side to side, then pull back on it and it should separate.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2015
    Tamaqua pa
    2
    thank you, thats what i thought, guess i need a bigger hammer, lol
