Thread: cyrunatic acid
    Jun 2015
    Hazel green al
    2
    cyrunatic acid
    Does the intex cg 28669 create it's own or do I have to add this to the pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: cyrunatic acid
    Welcome!
    You need to add stabilizer. Also known as CYA or cyanuric acid.
    What chemicals do what and how to add them are in Pool School - Recommended Pool Chemicals
    Jun 2015
    Hazel green al
    2
    Re: cyrunatic acid
    Thanks was afraid of that the cs8110 made life easy but it on the fritz
