Results 1 to 8 of 8
Thread: Filter 24/7?
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Filter 24/7?
    Another newbie question here...am I supposed to run my pump/filter 24/7? Do you guys? The pool guy (I know, I know...) told me to, but a friend who also has a pool told me that's insanity. *This question brought to you by my husband's near-heart attack when we got our power bill today.*
    Thanks!
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Filter 24/7?
    Three hours a day works for me.
    Pool School - Determine Pump Run Time
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Filter 24/7?
    Running mine 24/7 would bump the electric bill up by $150 a month. Not gonna happen. I run mine about 7-8 hrs a day because I think the water looks prettier when its moving.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Re: Filter 24/7?
    Thanks, Richard! I really appreciate all of your advice over the last week or so.
    Wendy
    TF-100 Test Kit
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Re: Filter 24/7?
    I run 4 hours a day. 2 hours in winter. I have a 2 HP single speed pump, so I could imagine my bill running it 24/7
    Ours is on an Intermatic timer, so I have it set for 1 hour in the morning, and 3 in the evening. Seems to work out nicely, and I have plenty of time on the 3 hour run to test and add chemicals as needed. If I have a lot of swimmers, I kick the pump one to help filter the water.
    It's something you'll have to experiment with if you have a timer. Keep decreasing the time until you are unhappy with the filtration and then increase from there.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Filter 24/7?
    Quote Originally Posted by n240sxguy View Post
    Yeah, I like the looks of it when there is some movement in the water. Currently ours is set for about the same as you, 6-8 or so hours.
    Apr 2015
    Knoxville, TN
    64
    Re: Filter 24/7?
    To keep my chlorine up, I have to run the swg 10ish hours a day b
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Filter 24/7?
    Quote Originally Posted by Rere View Post
    Is your swg undersized? Are you running it at 100% for 10 hrs?
