Results 1 to 9 of 9
Thread: Need wiring help for 2 speed pump
    Dec 2013
    Wakefield Ma
    33
    Last storm pump got hit by lightning, pump body melted like a blob... pretty cool wish i took pictures... breaker popped for it and I also lost a tv... but im not angry... it was an old tv..
    Got a new pump assembly and looked at the wiring... thought to myself ahhh Ive done wiring this can't be hard.. boy was I wrong.
    Variable speed is overkill for my pool so I purchased a 2 speed unit.
    Pictures attached.
    Any help is greatly appreciated.
    31000 gallon in ground vinyl
    1 HP Hayward SuperPump
    65 sq DE filter
    Dec 2013
    Wakefield Ma
    33
    Re: Need wiring help for 2 speed pump
    65 sq DE filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    I guess the question is, do you have a toggle switch somewhere to switch speeds? Is there one on the pump somewhere? Because it should be a snap if you have the toggle switch at the other end of the flex conduit.
    Dec 2013
    Wakefield Ma
    33
    Actually there is a toggle which has a black a yellow and a white... the yellow and white are in the last link. however the black is capped on the switch.
    3009 has the picture of the toggle...
    I know Im missing something simple here... And I feel Im over thinking this..
    My thought is power should come in to the pump and the toggle should complete the circuit to either the yellow or white depending on the speed.
    But the black is capped.. as well as capped in the motor...
    65 sq DE filter
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Assuming you have 120v run to the pump, since you have white and black, and the pump plate says prewired for 115v:
    Green wire to ground screw.
    White wire to #1.
    Black wire to black wire on switch that has the cap on it. No idea why they cap that wire. It confuses things.
    The switch plate is already prewired to #2 and #3 or 4.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Dec 2013
    Wakefield Ma
    33
    Quote Originally Posted by n240sxguy View Post
    White wire to #1.
    That is absolutely what got me... I was curious why they would cap it...
    Thanks folks greatly appreciated.. Im off to Home depot to grab some wire nuts for the black... thanks again..
    65 sq DE filter
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by jbelliveau View Post
    No problem. The wiring diagram for the toggle switch on the motor didn't do you any favors either. God forbid they actually complete the lines going to a circuit that they prewire.
    Dec 2013
    Wakefield Ma
    33
    Ironically my wife told me maybe they just capped it for packaging...
    I told her I have never seen that, they usually just strip the wire and leave the stripped end on with a small gap.. not actually cap it... and the diagram I thought was just mis printed until I looked on the website and its just as bad...
    65 sq DE filter
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I've seen a couple posts on here about wiring on just like that. They were all capped. Usually wires that are meant to be used are just as you described. They start to strip the wire, then just leave the jacket hanging to keep the wires from getting frayed.
