Thread: Interesting ad from a pool store
    Aug 2014
    Seminole, FL
    92
    I wonder if their employees tell customers the same things? Although this is the first time I've heard that stabilizer causes stains!
    Built 1980, 19' x 30' almost rectangular, screened 15,000 gal, plaster, Hayward DE 3620 filter (currently using cellulose), Emerson 1081 1HP pump, AquaCal Heatwave SuperQuiet SQ110R heater, Zodiac T5 Cleaner, Taylor K-2006 test kit
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Interesting ad from a pool store
    That is interesting. I bet its like walmart starting to sell organic. If you can't beat em join em. Sell what the people are looking for.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    regarding the staining you mention,
    I think your referring to the 'no-scaling' category in the add.
    they do mention calclium which is whats used as a stabilizer in Cal-Hypo. That can definitenly cause scaling and staining if pool chemistry gets out of control.
    CYA stabilizer - I havent heard of any occurences where it caused staining, except by putting granular CYA directly in the pool and not using a sock or some other container to keep the acid off the pool surface.
    Quote Originally Posted by mikech View Post
    Divin Dave,
