Thread: High Salt ?
    Jun 2015
    Ridgewood, NJ
    11
    High Salt ?
    Getting started win Intex 1800 gal pool, added 50 lbs of salt and SWG threw error code 92 for too high a sat level.
    How much do I drain from the pool and refill? I did not think 50lbs would be too much.
    Thanks!
    Brian
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: High Salt ?
    Ah, you haven't discovered Pool Math. It can make calculations for all your pool needs. It says 50 pounds of salt in a 1,800 gallon pool would raise the salt level 3319. What level does your SWCG want?
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: High Salt ?
    Congrats on the new pool!
    How many lbs does the manual say to add and what is the target ppm?
