Results 1 to 11 of 11
Thread: OmniLogic not detecting HUA for Hayward VSP
    Jun 2015
    Lufkin/TX
    4
    I just installed the new Omnilogic Control Panel. When I try to configure the VSP, it does not show up in the list of detected devices. It appears that the OmniLogic panel is unable to "see" it and therefore unable to obtain it's HUA. High voltage wiring is directly to the breaker. Low voltage wiring is to the LS Comm bus as described in the instructions, which is the same as for the ProLogic panel I replaced.
    I read in another post that it may be necessary to upgrade firmware for the Hayward VSP. Anyone know how this is done?
    Oct 2014
    Central PA
    87
    What pump do you have, I was told that only Tristar or ecostar pumps are able to be interfaces with the omnilogic, I am in the same boat as you, as I have a super pump vsp, and am waiting for my pool builder to switch the pumps out
    Jun 2015
    Lufkin/TX
    4
    Re: OmniLogic not detecting HUA for Hayward VSP
    I have the Ecostar pump, Hayward SP3400VSP, which I upgraded to in 11/2013. Before the Omnilogic install I had the ProLogic panel that only allowed setup as a 2 speed pump. The old panel had issues like failing to turn on my chlorinator from time to time, overheating and one time it didn't reset the valves properly and drained my spa. Rather than replace with same panel I decided to upgrade. I could try to set up pump as 2 speed but rather use as a variable speed for obvious reasons.
    This is my second home that I am trying to sell and am only around on the weekends. I wasted so much time trying to configure the pump that I was unable to finish the configuration. I am using the pump in standalone mode and have some chlorine tabs in the pool until next weekend. Hopefully someone from Hayward can assist me this.
    18,500gal gunite pool with spill over spa & waterfall built in 2009
    OmniLogic Control Panel, Hayward T-Cell-15 Chlorine Generator, Hayward SP3400VSP(installed 11/2013)
    SmartFilter 450/550 Cartridge Filter, Sense & Dispense Acid Feed with Stenner pump
    Pressure Cleaner w/ Hayward 3/4HP auxilary pump, SmartMax(Emerson 1.5HP0 Waterfall pump
    Jun 2015
    Lufkin/TX
    4
    Just spoke with the Hayward rep. He said that I need a new Digital Display, Part#VSX3400LCD, for the 3400VSP since my unit is so old(18 months) and predates OmniLogic. Got it ordered and should have it to install by the weekend. Only $328.76 on Amazon(sarcasm). Will post update.
    Jun 2014
    Los Angeles, CA
    104
    Hayward has a little racket going with the lack of compatibility of pumps and automation and lack of information to the consumer. When they advertise the OmniLogic, they shouldn't say compatible with Ecostar, rather they should say compatible with Ecostar manufactured after XXXX. Same for the Tristar, they should say compatible with Tristar model number XXXXX.
    -Shotcrete Pool. Pebble Sheen. Tile by Dal Tile CW27 Winter Blues. Pool dimensions 45x19 24,360 gallons. Spa dimensions 7x7 825 gallons. -Hayward Equipment: OmniLogic, Main filter pump Ecostar SP3400VSP, Spa pump Ecostar SP3400VSP, Filter 700sq ft Cartridge Filter HCF7030C, T-Cell 15 SWG, GVA 24 valve actuators, Universal ColorLogic 12v LED lights, H500FDN Natural Gas 500,000 BTU heater, TF100 test kit.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    I will pass this information on.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    ashmoussa's Avatar
    Sep 2014
    Jefferson (Lake Hopatcong), NJ
    113
    Quote Originally Posted by ClubJuan View Post
    Hi ClubJuan,
    So did it work? I think I might be in the same boat.
    Quote Originally Posted by Hayward Pool View Post
    Hi Hayward Pool,
    Any updates/information on this issue?
    Thanks.
    May 2015: 17K Viking Caribbean Fiberglass IG pool (16'x40'), PAL lighting three 2T4 LED's (inside pool), Hayward DE 6020, Hayward Ecostar VS pump, SWG TCell15, Hayward HP21404T Heat Pump, Hayward Omnilogic automation + Sense & Dispense (HLCHEM).
    Rest of the backyard ideas/wish list: 12 x 20 Pergola, 48" Round Firepit, Accent/Landscape lighting, Outdoor movie theatre and music (projector & speakers), etc...
    ashmoussa's Avatar
    Sep 2014
    113
    Unfortunately, Hayward did me wrong bigtime!
    I called in to Hayward support to troubleshoot this issue between the communication fault between the Ecostar pump and the Omnilogic. After doing a little bit of troubleshooting with me on the phone, in front of my equipment, they determined that the Ecostar I have is incompatible with my Omnilogic. Weird huh??
    What they tell you everywhere is that the Omnilogic will control up to a whopping 8 Ecostar pumps. But what they DON'T tell you anywhere, even in their troubleshooting guide, is that the Omnilogic won't communicate with Ecostar pumps made prior to 2015! Well that sucks now doesn't it??
    The Omnilogic was launched somewhere between the end of 2014 - beginning 2015. And being that most pool builds are done during the spring-summer season, 2015 spring-summer would be the first for the Omnilogic's. And its not unheard of that most pool distributors/PB's have all sorts of equipment leftover from last year (2014). So how can Hayward make a such a FALSE statement that their Omnilogic's are compatible with up to 8x Ecostar pumps without stating that the requirement is that the pump should be manufactured this year 2015? False advertising if you ask me!!
    Also, how could Hayward not think about this and make these Omnilogic's backwards compatible or at the least have a workaround for people who have these Ecostars from prior years?? I called tons of distributors/resellers, authorized warranty reps, PB's, etc... and NONE of them, not even one, knew about this issue. How could Hayward even launch/deploy this item without giving adequate training, information, and/or heads-up on these units.
    Now, I'm stuck having to buy another part to fix this issue that costs upwards of $900 just to get the communication between the pump and the Omnilogic!!!! And Hayward will not even do anything to make this right. WHAT!!?!?! This is nonsense!
    Hayward dropped the ball big time and has left us early adopters out to dry. Way to go Hayward!!!! Lesson learned.
    This seriously impacts Hayward's potential customers. Especially those who are shopping around for PB's to build their pools. Since most PB's stick with one pool manufacturer for their builds. Had I known this from the get go, it might have swayed my decision on choosing a particular pool builder and/or, more so, a pool equipment manufacturer.
    You live and learn...
    THANKS HAYWARD!
    ashmoussa's Avatar
    Sep 2014
    113
    I would like to report that it worked!!!! I bought the LCD module ClubJuan suggested, installed it, and it worked!! The HUA address popped up on the Omnilogic config screen. I can now control my pump from anywhere.
    Thank you ClubJuan for the tip.
    Jun 2014
    Los Angeles, CA
    104
    Quote Originally Posted by ashmoussa View Post
    Yes it will work, but you are out an extra $300. They should still fix their literature and inform the distributors.
    ashmoussa's Avatar
    Sep 2014
    113
    Oh I agree completely.
    But I gave up on Hayward. Shame on them.
