Thread: CYA Test Help
    Jun 2015
    Cedar Run NJ
    17
    CYA Test Help
    I am having trouble understanding how to correctly perform this test, I've watched the videos and have read instructions several times.(I have the Taylor TF-100 test kit)
    The black dot fades but doesnt fully disappear, all of my other test numbers are where they should be(TA at 60 May need to raise?) and water is crystal. Any help is appreciated. Thanks in Advance
    17x37 IG 20,000 gallons Pro Grid DE Hayward filter, Lighted waterfall with slide use BBB.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: CYA Test Help
    If the dot never fully disappears, then your CYA is less than 20ppm. You can pour the solution back and forth so you can re-read the test several times and average your results. Sometimes it helps to look at the dot with one eye, look away a few seconds, then look for the dot again. Consistent lighting is important, so full sunlight, back to the sun holding the reading vial at waist level is recommended. If you can still see the outline of the dot, assume the CYA is 20 and add enough to reach 30ppm.
    Love TFP? Become a
    TFP Supporter!
    Jun 2015
    Cedar Run NJ
    17
    Re: CYA Test Help
    Thank You for your help, would you recommend I use liquid muriatric acid?
    Mar 2015
    Harvey, LA
    300
    Re: CYA Test Help
    Quote Originally Posted by Yankees View Post
    No, that won't affect CYA. CYA stands for cyanuric acid; this is a separate chemical, often called stabilizer in the pool store. Adding muriatic acid will lower the pH, but will do nothing for your CYA levels.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Jun 2015
    Cedar Run NJ
    17
    Re: CYA Test Help
    Thanks again Zea
