Thread: Rust spots bottom of pool liner
    New Engalnd
    114
    Hello,
    I dove down today into the pool with goggles and saw some rust spots. I thought maybe black algea but they didnt wipe away.
    questions,
    what is most likely the cause? and how do i know if its a big deal or a one time deal(or can this rust sort of expand..sorry if thats a bad question)
    is there a safe way to clean them (pool is obv full of water etc).
    As always thanks for your help
    Matt
    Hayward Pump 3/4 HP - brand new
    sta rite sand filter - not sure of size, i will get back to this
    20 by 40 inground pool, vinyl liner, 8ft deep end
    2 skimmers and a main drain.
    1 jet in the deep end, 1 jet in the shallow end.
    Live in New England = about 3 months of pool usage.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Rust spots bottom of pool liner
    Could anything have layed there over the winter? Were they there when you opened?
    New Engalnd
    114
    I am thinking it was something in there over the winter. I've spent the last 30 minutes replaying the entire opening and shocking process. I think a brush may have been in there. But can it expand or is it a one off.
    Matt
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Once the metal is removed, the stain should stop spreading. The tiniest but of iron or steel can leave quite a large stain. Some Vitamin C tablets piled on should lift it. Check out this picture:
