Thread: intex sand filter to coleman 16' power frame pool
    for those who are wanting or thinking about upgrading from a stock cartridge filter to a sand filter for a Coleman 16' x 48" power frame pool. I would recommend doing this upgrade , the cost of the sand filter will pay for itself in no time with not having to buy the cartridges all summer and keep your pool looking much cleaner. I was running the stock filter all the time for the 1st week and realized that the stock filter was way undersized ! I'm currently running the sand filter on it's timer 2 hr.'s a day "pool is crystal clear" but will more in likely bump that up when the weather heats up and the pool is getting used a lot more.
    I did not need any other fittings / adapters etc. to hook up the intex SF70110. I removed the supply and discharge hoses from the stock filter and screwed the coleman stock hoses right to the new intex filter. the intex sand filter will come with 2 hoses to hook up to the valves on the pool but I put these away for extra parts if needed later on....the intex hoses are the same as the stock hoses that come with the coleman 16' power frame pool.
    I ordered my filter through amazon. hope this helps those of you wanting to upgrade ! any questions I'll try to help...I'm no pool expert but this forum is really helping me.
    24' x 52" VINYL AG 15,200 GAL.
    HAYWARD POWER FLOW LX 1.5 HP
    HAYWARD SAND FILTER
    Taylor K-2006
    Jun 2014
    15,221
    Re: intex sand filter to coleman 16' power frame pool
    Drywall, thank you for sharing. I'm sure someone will take advantage of this info at some point.
