Thread: Low Salt Issue
    May 2015
    Lexington, KY
    73
    Low Salt Issue
    I'm not sure if I'm posting in the right forum, but today, I got a "Low Salt" and "Check Cell" light on my Aqua Rite SWG. The display gave me a reading of 2700 for salt. Here are some stats:
    1. Over past 24 hours, my pool has filled up an additional 3"-4" with rain water. We are getting quite a bit of rain. Temperature outside was upper 80s yesterday and upper 70s today.
    2. Salt test yesterday: 3000.
    Salt test today: 2800.
    3. FC yesterday: 3
    FC today: 5 (I noticed my FC was low so I ran my SWG for 24 hours @ 50%. I had only been running it for 4-6 hours for the last 7 days at 40%).
    4. CYA: around 60.
    5. I bought this home in September 2014. I have no idea when the cell was last cleaned. I opened this pool on May 6, 2015.
    Based on my manual, it is stating that I should clean the cell. Here are my questions:
    1. Should I clean the cell? It seems I've read on here that the cell would have an issue if my test readings and the display readings from the SWG were consistently off by more than 400. My SWG display is at 2700 and I did two tests today and they both came up to 2800. My display and my tests have never been more than 200-300 apart. So does this mean that the cell does not need to be cleaned or is going bad?
    2. Or is this a simple issue as to add more salt to keep up with the increase in water in the pool?
    Thanks for all of your guidance and help.
    Pool Owner since Sept. 2014, but 2012(ish) in-ground pool. 40'x'20x3'(shallow)-8'(deep). Around 28,000 gallons. Vinyl liner. SWG. Aqua Rite with Hayward T-15 cell. Hayward Super Pump (self priming). Hayward Sand Filter. AquaPro Pro1100e Heat Pump. 2 main drains. 2 skimmers. 2 jets. 1 light. 1 diving board. Dolphin M4. TF-100 Test Kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Low Salt Issue
    Sounds to me like you just need to add salt. Most SWGs prefer salt 3200-3400. Around here we like to say if the SWG is happy then we're all happy.
    May 2015
    Lexington, KY
    73
    Re: Low Salt Issue
    Thanks pooldv. So you think the "low salt" light triggered the "check cell" light? I did not know that I would have time to add salt (and see if that removes the error messages) or if the cell needed immediate attention.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Re: Low Salt Issue
    If your "inspect cell" light is on, you need to clean your cell, following the manufacturer's instructions. I use a number 11 winter plug on the end of the cell that doesn't have the power cord, put it in a bucket, then put a mixture of muriatic acid and water (I can't remember off the top of my head, but I think it's 4 parts water to 1 part acid). Then I let it sit for about 5 minutes and then take the plug out, and give it a good rinsing with a garden hose. The panel is configured to come up that the cell needs to be cleaned after so many hours of use and sounds like yours could be a regular scheduled maintenance cleaning is due.
    I would also add salt and you can use the pool calculator to determine how much to add.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    May 2015
    Lexington, KY
    73
    Re: Low Salt Issue
    Thanks for the advice. I had thought about cleaning it, but I have procrastinated and have not bought a cell stand yet. From YouTube videos, it looks like a simple process, as long as I don't have 3rd degree acid burns. Lol.
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Low Salt Issue
    Hello, wkusae31,
    Just a follow up. I'm in my second year with my SWG and while getting the pool "right" for summer, mine would give me the inspect cell on occasion along with low salt. That was when I had pump running at least 8 hrs a day.
    once pool was clear and I added some salt all is fine.
    Also one day my display will show 3700 and a day or two later 3800. I think that is when cell is generating chlorine from the salt and when it turns back into salt the displays the extra salt.
    If you haven't checked out pool school and the section pertaining to SWG pools, I highly recommend it, as it helps us understand our SWGs' and what levels we should run at. I followed those settings and verything is humming along great
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
