Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: FC too high?
    Jun 2015
    Sherwood, AR
    13
    Unhappy FC too high?
    Currently have been reading up a lot on here.. Started buying bleach instead of pool store chemicals.
    I returned from vacation and my pool was green and filthy. I started pouring 4 bottles (121 oz) of 8.25% chlorox bleach in at night.
    Received my TF-100 today and my CYA seems perfect. (40ish) but i was just doing my FC test and it took 90 drops to clear the test water...
    45 PPM?!?! WHUT?
    What do i do?!
    and mind you, the pool is more blue than green now but still can't see the bottom at all.
    38,457
    Re: FC too high?
    Welcome to TFP!
    Just let the FC drift down on its own and then maintain the shock FC to follow the SLAM process.
    The FC should be in the 20s by tomorrow due to sun. loss
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Roger that.
    Any clue on why it still looks so uninviting?
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    UPDATE: Turned the pump off last night around 7pm FC was around 33.
    This morning the pool looked much clearer but a fine dust was settled on the bottom (Hooray for finally seeing the bottom)
    Minutes after I turned the pump on the water started getting cloudy... Ideas?
    Oh and FC was the same this morning
    38,457
    Re: FC too high?
    You need to follow the SLAM process.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: FC too high?
    To follow the SLAM process you pump needs to be on 24/7until you pass all SLAM criteria.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: FC too high?
    Please add your pool info to your signature so we can better help you. More info here, Pool School - Getting Started
    Here is a link to the Pool School - SLAM - Shock Level And Maintain
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: FC too high?
    That "fine dust" is most likely dead algae. Filter it out until SLAM completed and watch the filter pressure. Backwash/clean as needed.
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Well the reasoning behind turning it off was i wanted to see the bottom to vacuum. I've been trying to vacuum for days buy it was blindly.
    I am following the SLAM process.
    I appreciate the quick replies everyone! This entire website has been a lifesaver.
    25,000 Gallon
    In-Ground Vinyl
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Pool is still cloudy but blue in appearance. Have had the pool shocked and pump running for over 6 days... Normal?
    25,000 Gallon
    In-Ground Vinyl
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: FC too high?
    A SLAM is a process. It does not happen overnight. This is perfectly normal. Just keep the SLAM up until you pass all the criteria.
    Lisa
    38,457
    Re: FC too high?
    Please add your pool details to your signature as described HERE as it will help us help you.
    Specifically looking for filter type/size and pump type/size.
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Ill take a look at the pump setup in a bit.
    25,000 Gallon
    In-Ground Vinyl
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Cant edit my sig website is all messed up.
    1HP Hayward Pump
    Hayward pro series sand filter..?
    FC 16.5
    CC 0
    CH 250
    TA 90-100
    CYA 35
    PH 7.5
    Results as of 4pm
    currently 11pm still cloudy.
    IMO Those results are spot on. The CC indicates there isn't algae? Im still learning here.
    25,000 Gallon
    In-Ground Vinyl
    DFW, TX
    24,502
    Re: FC too high?
    Yes, there are some issues with the website right now. Numbers do look good.
    PH test is not valid with FC above 10 so you can save that test for later.
    CC, no CC is good but it does not mean there is no algae. More than .5 or 1 CC means there is an issue in the pool. I had algae in my pool a week and a half ago. My FC dropped to 1.5 due to heat, lots of swimming and a lazy tester. Water was crystal clear as it has been for 3 years. And CC was 0 then and through my SLAM.
    An http://www.troublefreepool.com/conte...loss-test-oclt is a better indicator of something organic/algae in the pool consuming chlorine.
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Sounds good. I'll do that tonight.
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    Oh do you think small leaks in the lines around my pump filter could cause cloudiness? I fixed them all as of last night and the PSI dropped by 3. Strange.
    DFW, TX
    24,502
    Re: FC too high?
    No, don't see how it could.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: FC too high?
    Do you have a main drain?
    It would help clear the cloud A LOT if that is opened up so water can come in from the bottom.
    I did a SLAM recently and after brushing each day I could not see more than 3 feet down on a 9 foot pool.
    With the main drain and skimmer full open and running the pump all but 3 hours a day (had some pump issues and couldn't run 24/7)
    the water went from that to crystal clear in 3 days.
    Dolphin E10 Cleaning Robot.
  20. Back To Top    #20
    Jun 2015
    Sherwood, AR
    13
    Re: FC too high?
    How would I close or open it? It feels like it's working with my hand over it. Still cloudy.
