Flashing red light, clean cell, check flow problem solved, underlying problem from the Autopilot DIG 220 power supply:
I had above problem, which made me check the main board on the power supply . I saw there were 5 electrolytic capacitors blown. They were bulged and black electrolyte was oozing out on top. I checked a pool company for the replacement board, there are none, one has to buy the DIG 220 complete box for $600.
If you look at the board once you removed the casing and the metal protection cage, you see 5 capacitors on the left about 1.2cm in diameter (.7 inch), the value is 1000uF/50V. There is a 6th one on the right side, that is probably ok, was in my case. I took the board out. First you have to disconnect it, I always make photos before I do that, but in this case the connections are clearly marked, so no panic in case you forget. There are not only the screws holding the motherboard, there is also a bigger one , which holds a rectifier in place and, I think there were 8, to hold the transistors on top to the cooling strip.
Once you have removed the board, get the 5 capacitors ($6 from RadioShack or $2 on eBay). But don't get any lower voltage!!!, make sure they can withstand 80 deg C, or 135 F, and a soldering iron for less than $594 incl. the solder. (that's just the economist talking). Remove the old ones and put the new ones in. Just make sure the polarity is correct, + is marked on the board. If you get ones with both connectors on one side that's better, If you get them with the connectors on opposing sides , no problem, you have to cut off a piece of the connector of the side which goes on the board and extend the one now on top with the cut off piece to reach the board. Or you put the capacitor in polarity wise on the wrong side, clip it off 4mm from the capacitor, turn it around and put it in the right way and solder the now longer piece to the leftover already soldered in. (just the technician talking). Put everything back in place and reconnect the board and sell the soldering iron on eBay.
Now as a last item check if the 2 fans on top come on, if that's not the case this might have been the problem in the first place. Check the voltage on the connector of the fan or inspect them visually (if the voltage is there that means the fans are bad) If you see the cables to the fans are rotten of on the solder point on the fan, that means they are bad.
Now you can either replace the fans ($5x2 on eBay 12V 1W ) if you replace go up to 1.5W - or what I did, throw them away, get one 120 or 140mm fan for a PC cut an opening in the plastic cover under the flap and put the fan there, the voltage is 12V no problem there. Then cut the sides of the flap that the air has a way in. That keeps the unit really cool. Remove also the mounting plate of the original fans.
I can also provide photos, but I think it's pretty clear. Both clean cell, and check flow didn't come on again (unless the pump just started or the cell is really bad)
