Results 1 to 7 of 7
Thread: Math Trouble
    April's Avatar
    Apr 2014
    KY
    138
    Math Trouble
    This may be a stupid question but........Im trying to figure out how many gallons are in my friends pool that I'm helping her slam. I thought I could figure it out by how many gallons of chlorine I had added to get her to her slam level but math is not my strong point. So any help is appreciated.
    She thinks the size is a 20x40 IG Grecian. Shallow end is 4' deep end is 8'. But she is not positive.
    So I added:
    4 gallons of chlorine 10%
    Raised her FC to 13.
    Is it possible to figure out the gallons this way?
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    38,248
    Re: Math Trouble
    Not very exactly. Since you do not know the exact strength of the bleach.
    Assuming it is really 10% and you started at 0ppm ... PoolMath estimates it would be 31k gallons.
    Although using the volume calculator, it could be a little more than that if the dimensions are correct.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Math Trouble
    Hi April,
    For calculating how many galollons in a pool (or any other rectanular or square container)
    the formula is L*W*D = cubic feet of volume
    There is 7.47 gallons in 1 Cubit Foot of water - so,
    Gallons = Cubic Feet * 7.47
    Or - why not just use pool math to help you?
    Towards the bottom of pool math is a volume calculator.
    Just measure the length and width of the pool. For the depth, do an average. Deep End + Shallow end divided by 2.
    Or, you can play around with pool math by changing the volume and using the 4 gallons raising the FC to 13 and nail it that way.
    http://www.troublefreepool.com/calc.html
    If you want to calculate the pool volume chemically, then here is the best way to do it. (this should impress your friend!)
    A Chemical Way of Calculating Pool Volume
    hope this helps,
    Divin Dave,
    April's Avatar
    Apr 2014
    KY
    138
    Re: Math Trouble
    Thank you Jason and Dave.
    I didn't know if pool math would be correct because the sides of the pool slope in. Like this \_/.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Math Trouble
    Yup,
    it does account for the slope. to some extent. Not all pools will be exactly equal slopes though, but pool math should easily get you within a few hundred gallons.
    Its easy enough to tweak it from there.
    Quote Originally Posted by April View Post
    Divin Dave,
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Math Trouble
    Just to be precise, there is 7.48 gallons/cu-ft.
    Mark
    April's Avatar
    Apr 2014
    KY
    138
    Re: Math Trouble
    Thank you everyone. I'll use 28k to start out with and adjust from there.
