Results 1 to 7 of 7
Thread: Want to test your skimmers?
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Just have the grandkids over
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Jun 2014
    15,192
    Re: Want to test your skimmers?
    Bwaahaahaaa! Very true!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,631
    Beats having them choked up with slices of limes.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    That is weird. It happens to me too. A flower petal will pass two inches in front of the skimmer throat and pass by, but a 3/4 submerged squirtgun bobbing around will make its way across the pool and over the weir and into the skimmer basket without fail.
    Mar 2015
    380
    Yeah, the wife has a lot of ferns and other plants inside the enclosure. Wind during the night carried some stuff into the pool. Those just seemed to circle the pool until they sank but both skimmers had no problem sucking in toys, lol.
    I'm still messing with pump speeds and times though, and this morning it started out on the low end. I think when I set it to first start in the morning it shouldn't be on low. I likely sank stuff before the higher speed hit and the skimmers working. Fun playing with it anyway, even if not trying real hard to decided when, and how much, to run until company is gone and back to the normal routine
    Scott
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Quote Originally Posted by woodyp View Post
    At my age, I would have to disagree.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    You're not the only one. I get to deal with this mainly due to my returns not having eyeballs. My returns are simple PVC pipe cut flush with the plaster wall, no way to alter the direction.
    I end up will leaves and debris going right past the skimmer and make the full circle around the pool. I will find Howard, my floating thermometer duck, in the skimmer from time to time. Also splash bombs and other floating toys. I think a Toypeedo got in there once as well.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
