Thread: New Filter Timer
    domct203's Avatar
    Jun 2015
    CT
    3,591
    New Filter Timer
    Sick of being locked into a timer "window" with the built in timer on my Intex system, I bought a Woods Digital timer and made a small outdoor box for it from some pressure treated scraps I had laying around.
    Everything plugs into into a proper GFCI outlet, power cord to timer is 14ga, about 20' long.
    It's pretty stable with both legs about 6" into the ground, and it's nice to have a GFCI protected outlet right next to my pool cabinet.
    Dom
    Edit: Forgot a pic.......
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2014
    15,165
    Re: New Filter Timer
    Handy and very nice DIY work.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Fancy! Nice work!
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Nice. Do you plan on replacing the extension cord you have supplying the outlet? I'm guessing you have the other end plugged into the GFCI outlet?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    domct203's Avatar
    Jun 2015
    CT
    3,591
    Quote Originally Posted by ps0303 View Post
    It will stay as is, and will be pulled for winter storage with the pump.
    Yes, GFCI protected.
    Dom
    Dom - TFP Guide
