Results 1 to 9 of 9
Thread: I have a screw loose
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Exclamation I have a screw loose
    In the pool. I dropped it while installing a Hayward through the wall skimmer. My pool is a lovely shade of green, and I can't see it. Blindly scooping with the net has hit the screw, but wasn't able to pick it up. I tested the remaining screws, and the are not magnetic (was going to try a magnet on a string).
    Can the screw be safely vacuumed, or is it time for a swim in the swamp?
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: I have a screw loose
    stretch a kneehigh nylon over the vacuum hose port and ram the hose on to snag it when you vacuum it up
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Sounds great! I'll give it a go!
    It didn't occur to me until you said that about the kneehighs - I'm vacuuming through the skimmer! It will be caught in the skimmer basket! Doh!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,383
    You just wanted to play Creature from the Black Lagoon! LOL
    Kim
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Hehe, screw retrieved. I did get in the pool to install the skimmer, but I borrowed a friend's waders. ��
    Casey's Avatar
    SW PA
    10,421
    Waders are a great idea!
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    He failed to tell me of the hole in the crotch, so shortly after I got in, I noticed it began to get a bit chilly in the waders... ��
    Jul 2012
    Tallahassee, FL
    30,383
    OH NO! BAD Man! I bet he was laughing KNOWING what was going to happen! BAD!
    Kim
    Jul 2012
    Tallahassee, FL
    30,383
    Kim
