Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Just Uncovered Pool and Need a Little Help
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    I uncovered my pool two weeks ago. Vacuumed and cleaned all week, began testing water and I need some suggestions.
    The water is clean but cloudy.
    PH - 7.3 looks good
    CL - is way low at about 1.3 or lower. I've been adding bleach for two weeks now and it still hardly registers.
    I ran out of CYA regent, but could still see the black dot. I think it's about 20, not sure.
    I've ordered more regent and it should be here this week.
    Is there anything I can do or try until then that might help?
    I've been backwashing and running the pump for 24/7.
    Thanks
    16' x 32' Vinyl IG, 15K Gal. (not SWG)
    1 HP Hayward Super-Flo Pump, Pentaire Sand Filter
    Hayward Automatic Chlorinator
    Polaris 380 Pool Cleaner w/booster pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Just Uncovered Pool and Need a Little Help
    A SLAM sounds like it is order. Read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    • CC is 0.5 or lower;
    • You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    • The water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Hmmm... low CYA and massive chlorine appetite smacks of Ammonia.
    You could have the pool store test for it, or buy a cheap ammonia test at a pet store/aquarium.
    If you have a FAS-DPD test that allows you to measure CC, there is a way to check that way, too.
    In any case... the solution is bleach.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Thanks, but there is no ammonia smell, so CYA must not be so low.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    awwwwwww but you will not smell the ammonia. If only it were that easy.
    You can also put in 2 gals of bleach, run the pump for 30 mins and test for FC. Let us know the results of this little test.
    Either way-ammonia or no bleach is your friend.
    Kim
    30,403
    There is no correlation between ammonia and CYA. read "The ABC's of Pool Water Chemistry" up in Pool School. It will help you get started with a SLAM and will help you understand the importance of chlorine and CYA in your pool.
    Whether you have ammonia or not is not really important. What is important is that your FC is being consumed in excess. You stop that by SLAMming the pool.
    After you read the "ABC's", I would read the SLAM article, get your CYA reagent in and post a complete set of test results just before you SLAM....we'll help.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Quote Originally Posted by kimkats View Post
    Kim
    OK...going to buy more bleach and try this.
    Thanks
    I've read the ABC"s and Slamming Your Pool.
    I feel like I have read everything on this site twice over the past few years.
    I really need the CYA regent to get all of my readings, then I'll have more info.
    Thanks guys/gals for all of the input.
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Kim
    Added 2 gallons of bleach, waited 30 minutes and tested the PH and CL.
    PH = 7.6
    CL = 1.5-2
    Will test again in the morning.
    Jul 2012
    Tallahassee, FL
    30,410
    BB you are going to need a LOT of bleach. 2 gals of bleach should have pushed your FC much higher than that in 30 mins.
    If at all possible I would like you to test, add bleach to bring your FC to your SLAM level and retest in 30 mins. add to bring to SLAM level, repeat as much as you can.
    What you are trying to do is to get ahead of the lose of FC. You will KNOW when you are winning when you go to test and your have held more of your FC. At that time you can back off to testing every hour. Once you FC will hold move to every other hour.
    The harder you hit is today the fast it will go.
    BB can you also look at your date code on your bleach please. We just had one person that bought bleach with a date code of 2013!
    Kim
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Kim
    Will do. I'll add much more bleach today.
    I found two different Brands of bleach.
    One was $1.50 per gal @ 3%
    One was $2.28 per gal @ 5%
    Which is the better value?
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Hi you should get the strongest you can find so you don't need as much, e.g. 8% 10% or 12.5%
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Quote Originally Posted by poolnoob.ca View Post
    No matter the cost?
    Where can you get 8, 10 or 12%?
    Jul 2012
    Tallahassee, FL
    30,410
    Walmart has 8.25% for about the same as your 5%
    Kim
    Jul 2012
    Tallahassee, FL
    30,410
    My Ace Hardware and pool store has 11%
    Kim
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    Added 2 gal of bleach.
    CL level at 5 or above.
    Will test again in 30 mins.
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    452
    BB
    Dollar General also has 8.25% bleach... I think it's 2.98 for 121oz.
    I usually get mine at either Walmart, or DG.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    BB BMW's Avatar
    May 2013
    Alabama (Roll Tide)
    41
    CL is still around 5 or so.
    PH is still good.
    I'll check Walmart and DG for their Bleach %.
    I know some are over $3 a gal. and as much as I'm using, it's adding up. But I think the pool is improving.
    Jul 2012
    Tallahassee, FL
    30,410
    I am very happy to see that your FC (that is Free Chlorine please use that instead of CL) is still around 5 or so.
    If you have a pool store that is easy for you to get to some of them will let you put a deposit down on their jugs and buy their liquid chlorine that is 11%.
    Happy SLAMing!
    Kim
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    452
    I tried calling around Gadsden, AL and was told by ALL of the pool stores that they didn't have any liquid chlorine... seems that they all JUST sell trichlor, and Dichlor these days. But I have not given up looking.
  20. Back To Top    #20
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    i use dollar tree, awesome bleach. i tested it to be 6%. make sure it's the full gallon one. i have found that not all DT carry it.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
