Results 1 to 9 of 9
Thread: Great forum!
    Jun 2015
    Phx Az
    13
    Great forum!
    New pool owner here (came with house) small 15x30 oval above ground. Drained and cleaned the pool, filled in march. Had no idea how pools worked. Got pool stored. CYA high (100+) by the beginning of june from floating tabs. Drained a little over half. CYA now around 55. Now following your method for liquid chlorine. Water feels better looks clearer.. Thank you guys! One weird thing is every time i do a CC test CC turns up lower than FC. possibly bad reagent?? Im using a k-2005 test kit I will be getting a fas-dpd test soon. Yesterday was 114 degrees and I lost about 4 ppm FC. Pool is in the sun from sun up until about 6pm.
    FC 10
    TA 85-90
    PH 7.4
    CYA 55-60
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Re: Great forum!
    Welcome to TFP!!
    You want the CC to be low, "0" would be perfect. Think of it like your cholesterol, FC is the good chlorine, CC is the bad chlorine.
    Support the site
    Jun 2015
    Phx Az
    13
    Re: Great forum!
    I just dont understand how the CC color could be lighter than the FC. Shouldn't CC be the the same color or darker than the FC if anything?
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: Great forum!
    Welcome!
    Great forum indeed, I can not believe how clear my pool is now that I'm in control.
    The TFPC method is so easy compared to previous years (all the chemicals, time & $$$) that sometimes I feel like I'm guilty of neglect while I'm just lounging in the pool LOL.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2014
    Franklin, NC
    9,179
    Re: Great forum!
    Quote Originally Posted by particleman View Post
    We are talking about a FAS/DPD test, correct?
    Is this the test you are doing?
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Great forum!
    particleman- we are confused by your confusion. If your pool is clean there should be 0 CC. CC is what FC turns into after it's done it's job. So what you could see is FC going down and CC going up. But CC should always, except in a few special cases, be less than FC.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Phx Az
    13
    Re: Great forum!
    Ahh no we are talking about the test that comes with the k-2005 i will be getting the fas test soon. right now I have the k-2005. The new k-2005 block goes up to 10ppm Cl.
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    Re: Great forum!
    Possibly confusing CC with TC?
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    May 2014
    Franklin, NC
    9,179
    Re: Great forum!
    Ah, with the K-2005 you have to do subtaction:
    1 Rinse and fill small comparator tube to 9 mL mark with water to be tested.
    2 Add 5 drops R-0001 and 5 drops R-0002. Cap and invert to mix.
    3 Match color with color standard.* Record as parts per million (ppm) free chlorine (FC).
    4 Add 5 drops R-0003. Cap and invert to mix.
    5 Match color immediately. Record as ppm total chlorine (TC).
    6 Subtract FC from TC. Record as ppm combined chlorine (CC). Formula: TC - FC = CC.
    Support the site
