Thread: New Pool Chemical Guidance ?
    Jun 2015
    Ridgewood, NJ
    11
    Hi Everyone-
    New pool 2nd post.
    Info: 1800 Gallon intex 12" by 30" deep
    Setup and added water on Thursday, along with 50 lbs of salt (planning to use the SWG once I get the chemicals dialed in). Added 52 oz of household bleach yesterday, and approx 17 oz of stabilizer.
    Recorded measurement using HTH 6 way test kit are:
    CL-BT 5 and 10
    PH-7.2
    TA-looks like 200ppm (I kept adding drops waiting for the water to turn from green to red, not sure I did this correct or not)
    Looking for next steps to get it dialed in.
    Thanks!
    Brian
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: New Pool Chemical Guidance ?
    The next step is this one:
    Your pH will rise and as you add acid to lower it, the TA will also slowly go down. When it hits 7.8 PH, take it back to 7.2. Keep the FC up above 4 at all times and get that SWG going. Once the CYA is totally dissolved, everything should be fine.
    Jun 2015
    Ridgewood, NJ
    11
    Awesome thank you! It's not quite a swim weekend in the Northeast which is good, that will allow me to get it dialed in.
    So I assume I should begin running the SWG today/tonight?
    And I could use a quick understanding of which chemicals when out of balance are not good to swim in. I kind of got the FC if it's too high. but any other values that make the pool unswimmable?
    Thanks!
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by bb1100yankees View Post
    Thanks!
    pH and CC can irritate eyes and skin. Calcium buildup can cause scale, which is like grow-your-own sandpaper right on the walls. Bump your knee and get roadrash in the pool. Ouch.
