Thread: Is lake proximity added trouble?
    May 2015
    Ten Mile, TN
    74
    [Trigger warning- this post contains the words "pool store" - LOL ]
    My neighbor's salesman at the pool store told him he is at higher risk of algae in his pool because of our nearby lake (birds and wind increasing droppings into the water of algae)
    I'm not so sure....I haven't seen a problem yet. I'm guessing this is a myth.
    24' Round 14000 gal AG - installed June 2, 2015
    Saltwater Hayward AquaRite w/TCell - 9
    Waterway 26" sand filter w/ 2HP 2 speed pump
    Taylor K-2006 FAS-DPD Test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Is lake proximity added trouble?
    In theory sure, I'll buy it. However, it's irrelevant if your maintaining the FC as you should. Forget it and enjoy the pool if you are.
    Essential Links:
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    My pool is maybe 100-200 feet from my two acre pond and I'm sure that is a contributing factor for the number of critters in the pool. But as said above, maintaining proper FC is the key.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I think the risk is greater because swimsuits and pool toys go back and forth between lake and pool.
    30,432
    Algae will form in the Sahara Desert if the conditions are correct.
    Your fiends salesman who works at the **** ***** has not thought that through very well.
    Mar 2007
    San Rafael, CA USA
    12,082
    The bigger risk is for yellow/mustard algae since that may be found in some lakes, especially if one swims in one and then the other carrying the algae with them in their swim suits. For green algae, it is ubiquitous and blowing in the wind almost everywhere.
