Results 1 to 7 of 7
Thread: Late opening, cloudy water
    May 2014
    Windham, NH
    101
    Here we go!!
    Opened up, everything is good, no green water just cloudy. Pump has been running for two days now I tested water jut now.
    FC - 9
    CC - 0
    CH - 125
    PH - 7.3
    CL - 5
    BR -10
    TA - 90
    CYA - 60
    25k Gallon IG, Vinyl liner, In Floor Cleaning System, Jacuzzi Earthworks DE 75 filter, Hayward H Series Propane Heater, TF-100 Test-Kit
    30,421
    Re: Late opening, cloudy water
    Is there a question in there?
    May 2014
    Windham, NH
    101
    1. Safe to swim for kids as is?
    2. Added Murieta acid (22oz), stabilizer (66oz) and bleach (112oz)
    3. Anything else I should be doing to speed this up?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    If the clarity is good enough to see the floor, let 'em swim.
    Toss some brushes in and devise a game to see who can brush the most underwater or something. If they feel any slimy spots, tell 'em to scrub it away. Whatever the cloudiness is, a bunch of kids will certainly get it stirred up for the filter to grab it.
    May 2014
    Windham, NH
    101
    Can't see bottom yet, too cloudy. But I will stand over them like a hawk.
    With the above numbers, does anything seem at a dangerous level? Nothing jumped out to me, but I don't want to risk hurting the kids skin/hair.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    We generally say it is safe to swim when:
    PH is 7.2 to 7.8
    Chlorine is above the minimum level for your CYA
    Chlorine is below shock level for your CYA
    Water is clear
    Chlorine CYA Chart
    May 2014
    Windham, NH
    101
    OK,so hopefully tomorrow. I'm really close right now.
