Results 1 to 14 of 14
Thread: pH not rising
    Feb 2008
    Milford, CT
    333
    pH not rising
    Kids have been in my pool a couple times and complain of sore/dry eyes after they get out. Since all the other tests seem OK (results below), I presume its time to deal with pH. We opened the pool 2 weeks ago so Ive been waiting for the water to clear up. It is now basically crystal clear and Im letting the FC fall by itself. Turned off the SWG, etc. During the SLAM process I was using liquid shock.
    Current test results:
    FC - 10
    pH - 7.3
    CC - 0.5
    TA - 50 (waiting to get pH in line before upping this)
    CYA - 40
    Last night I added about half of the amount that pool calc recommended to get my pH to 7.5. Waited an hour (pump on), re-tested and still no pH change. Let the pump run overnight, re-tested this morning, still no change in pH. Our pH reagent is 1 year old and has never seen heat or sun.
    Is the FC level causing an issue with the test? I always thought it would cause it to read higher instead of lower, but maybe not.
    Or is the reagent suspect? Luckily thats an easy one to find if I want another bottle.
    TIA
    -Chris
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,605
    Re: pH not rising
    FC at 10 or above causes PH to read artificially high.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pH not rising
    Maybe they are, but you should not test pH with Phenol red at 10 or above FC. Usually, it is false high.
    I'm more concerned about the CC, and the unclear water. You were on a SLAM I take it, and the water isn't yet clear? If so, you didn't finish SLAM, and the kids shouldn't be in there. You may have enough CC to cause irritation, especially if it's closer to 1PPM. How old are the reagents? If you are in doubt because they are aged, you should replace them all. It's not worth getting bad results for the little money they cost. Especially again, if your kids are at any risk.
    Essential Links:
    Feb 2008
    Milford, CT
    333
    Re: pH not rising
    Quote Originally Posted by Patrick_B View Post
    I guess I shouldnt have said "basically crystal clear".
    I should take a pic....the water looks fine. Can see the veins on the leaves sitting on the deep end floor. I tested the pool before the kids went in yesterday and aside from the low pH, all tests were clear (including 0.0 CC)
    Last night I ran the FC test and CC was 0.0. Not sure what happened overnight but after the test this morning I call it 0.5 (there was a very very slight pink hue to the FC test when I was done, if you could use HALF a drop of reagent to make it go away, it probably would have)
    I will replace my pH reagent ASAP. All other reagents in the tests are fresh.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pH not rising
    Ok then, that's good. Sorry, I though you might have cloudy water and not be done on the SLAM. We see folks trying to shortcut sometimes, and understandable. Kids and big ones (like me) get impatient and want in. I'll also add, sometimes the irritation we find out is from kids being in the water all day, or just too long. That can happen in the nicest of lake water if you stay in long enough. Good to hear then...
    Essential Links:
    Feb 2008
    Milford, CT
    333
    Re: pH not rising
    Ooh yeah, they were definitely on my case to get in early but they are old enough to know the rules (if you cant see the bottom, dont even ask about going in). I know the FC is high but without any CC I figured they were good to go. Kinda wondering if the CC I "found" overnight is actually from them.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: pH not rising
    Your true pH may be much lower than you think. Read the captions and look at the pictures Accurate pH test during shock levels with R-007?
    Feb 2008
    Milford, CT
    333
    Re: pH not rising
    Saw that thread myself.
    What is the best course of action? Wait until fc comes down to believe the ph test?
    Richard320's Avatar
    Jan 2010
    19,004
    Re: pH not rising
    Quote Originally Posted by chrisexv6 View Post
    Yes.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: pH not rising
    I dont think theres anything wrong with your red phenol. Its lasts a good long time. Let the FC drop down and go from there.
    Divin Dave,
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Re: pH not rising
    normal pH of eyes is 7.0 to 7.3 as per this link . So if your water truly is 7.3 that should not cause any eye irritation. As those above have mentioned, do a reading with chlorine under 10ppm with reliable reagents to get a true reading.
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: pH not rising
    PH 7.2 to 7.8 is fine. Don't raise your TA unless your PH is is not stable. Let FC drop to 8 or 9 and test PH. Adjust as needed and monitor for a week or two to see how PH acts. If it stays stable then leave TA as is.
    Feb 2008
    Milford, CT
    333
    Re: pH not rising
    OK, FC is down to 8.5
    pH still shows 7.3. I know its in the acceptable range, but with all other levels being good, I have to think this has at least a little to do with burning eyes.
    Poolcalc says I need to add 1.5 cups of Borax to bring pH up to 7.5. I might add half of that and retest later.
    On the flipside, it didnt budge after the 1.5" of rain we got this morning, so Im guessing the TA level is acceptable.
    DFW, TX
    24,497
    Re: pH not rising
    I believe that the PH in eyes is 7.2 to 7.4. Your PH is not making eyes burn. It is fine if you want to use borax to raise it to 7.4 or 7.5.
    Burning eyes is usually caused by CC. If you don't have CC then adding 2000 ppm of salt is the next thing to do to help reduce eye irritation.
