Thread: Testing CYA with SpeedStir
    Feb 2008
    Milford, CT
    337
    What are the correct amounts of pool water and CYA reagent necessary for testing without the mixer bottle (seems ours got lost)? I thought I read it can be done with a regular grad. cylinder and the SpeedStir but wasnt sure of the amounts of each liquid.
    I have the original PS234 test kit and the CYA view tube reads down to 20 ppm
    Thanks in advance.
    -Chris
    22K IG vinyl, MaxFlow SP2302VSP pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Testing CYA with SpeedStir
    It's a 50/50 solution Cya/Pool Water when it's prepared. No need to speedstir it, but you can I suppose.
    I think it's 15 mL of each for that kit type. I will double check.
    Edit: Double Check is 15 mL for sure
    Essential Links:
    Feb 2008
    Milford, CT
    337
    Thanks!
