Thread: Stains...not sure what it is...
    Mar 2015
    Baton Rouge, Louisiana
    19
    So near my pool steps I now have white marks, they appear like bleached out markings that occur only near the steps. They are smooth from what I can tell so I don't think it's calicum, but my problem is it seems like more and more spots are showing up.
    I'm attaching a picture. .
    Test results
    Ph 7.6
    fc 7
    alk 100
    ch 200
    Stabalizer 50
    44,000 gallon IG vinyl liner pool. 1.5 hp single speed motor on E Z flow pump/sand filter. Unknown age of pool, Kreepy krauly vacuum, Taylor K-2006 Test Kit.
    Jun 2014
    15,173
    Re: Stains...not sure what it is...
    Hello dapeople! I see you haven't received a reply yet on your post. I just wanted to let you know we haven't forgotten about you. Your test results are actually quite solid. What test kit did you use? Also, can you provide your CC level as well please?
    This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Is there any chance that someone broadcast powdered "shock" or stabilizer granules into the pool? They'll leave white freckles if they sit on the surface too long. Even the simple action of rinsing the empty bucket with pool water to get rid of the crumbs could do it if they poured it out in that area.
    Mar 2015
    19
    Cc is 0. Taylor test kit k2006. No powder goes into pool! Just bleach
