Thread: Opening - on track with new liner but need a bit of help..
    Cool Opening - on track with new liner but need a bit of help..
    So we had a new vinyl liner installed this week. The installer had several trucks of water brought in and we are completing the fill with our garden hose. We are over the returns and almost up to the skimmers - using the main drain in the meantime for circulation. So last night I tested and added the following: CYA in a sock, borax, baking soda and bleach. Prior to this - the new water was crystal clear. I woke up this am and it is slightly green. I tested and got the following results:
    TA 40
    pH 7.5
    CYA can't read yet (just added)
    FC 4.0
    Should I be SLAM'ing the pool at opening before letting it drop to regular levels? It is a cloudy day today and I can add it every two hours until the sun comes out. Thanks for any help. Love this forum and the folks on it!
    ____________________________________________________________ _____________________
    Vinyl free form IG 30,000 gallon pool
    Hayward S270T Pro Series High Rate Sand Filter
    AO Smith 1081 Centurion Pool Pump
    Sliding Board
    TF50 Test Kit and Taylor Ph test kit
    Aquabot Tempo
    30,421
    Re: Opening - on track with new liner but need a bit of help..
    Good morning!,
    I suspect you have some iron in your water. Is thaty why you trucked in water? Did you get water that was supposedly iron free?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Iron and chlorine don't play well together. Are you on well water?
    We trucked in some water because the installer said we needed to in order to hold liner in place. Did not get iron free water as far as I know. I started adding more chlorine this am and it has cleared already. Will continue to SLAM until I pass OFCT. Thanks.
    We are on well water - I had well water tested and it is <.10 mg/L.
    Sliding Board
    Aquabot Tempo
    Casey's Avatar
    SW PA
    10,444
    That's why the water turned a slight greenish because of the hose water you added.
