Thread: My experience so far with BBB
    Sep 2009
    Lathrop, California
    12
    Hi,
    Although I joined this form in 2009 I was at the time using a SWG for chlorination of my pool. In 2013 the SWG died I was face with buying a new SWG or returning to traditional sanitation using 3.5 tabs or powered chlorine. I chose powered and it was easier the results were not what I was looking for. This went on for 2013 & 14. In the spring 2015 decided that i want to use BBB. I logged onto TFP website and read again what to do. I have been using BBB since March and I cant believe the difference my water is clearer and softer the PH stays stable longer, and the bleach actually last longer than the dry chlorine. I don't even use tabs to keep the chlorine level stable and no algae either. I see a big difference in $$$ also that I spend. So far this BBB program woks great.
    Mike T..
    1997 gunite white plaster 24x36 double kidney shape pool with attached spa ~25,000 gallons.
    Hayward PRO DE 6020, Sta-Rite 2 hp two speed pump, P4 Digital Controller, Navigator cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: My experience so far with BBB
    Welcome to TFP!
    We appreciate you sharing your experience with us. It does indeed work, no question about it. Although a lot of us do without two of the Bs it's all about understanding what's going in ther and why. Then adding nothing you absolutely don't have to have. Great to hear your story, and good to have you aboard.
    Essential Links:
    Jun 2014
    15,093
    Sometimes we just have to learn and see it for ourselves to believe. Glad to hear you understand and are using the TFPC methods to help you have a more enjoyable swimming season.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
