Thread: Human Creations Solar Pool Purifier
    Jul 2014
    San Jose, CA
    2
    Has anyone tried this product. Amazon.com : Human Creations Solar Pool Purifier (2-year warranty)-Blue : Swimming Pool Clarifiers : Patio, Lawn Garden
    It is supposed to take sunlight and ionization to purify your pool.
    Your results?
    20,000 Pebbletec 420 CCP Cartridge Filter, Spa with overflow 400K Heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    Re: Human Creations Solar Pool Purifier
    No!!! TFP does not recommend use of ionizers in pools. They add copper which will once it gets above 0.3 ppm will cause staining and turn hair green. And it does not sanitize the pool.
    More info here: Pool School - Metals in the Water and Metal Stains
    And here: Alternative sanitizers and pools--The Truth!!
    Mar 2007
    San Rafael, CA USA
    12,082
    It is especially risky given that you have a Pebbletec pool since plaster surfaces tend to be higher in pH and stain from metal ions much more readily than vinyl pool surfaces.
