Results 1 to 9 of 9
Thread: sun deck water depth
    MGood's Avatar
    May 2015
    Eldridge Iowa
    67
    We are in the process of finalizing our pool design and hoping to dig the first part of August. We will have a 6' sun deck that will be 20' wide with two bubblers. The water depth is at 9" on the sun deck. That seems about right but wanted other people's opinion who have sun decks. Thanks!
    20x44x30 L shape Only Alpha with 6' sun deck with 2 bubblers, 350k heater, 1 1/2 HP and SWG. Dolphin Nautilus Plus. Estimated construction start time is beginning of Aug.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: sun deck water depth
    Ours is about 6, 9 or 10 would be better. Make sure it is 9 to middle of the tile and not to bottom of coping. Pics in sig.
    Jul 2014
    New England - MA
    310
    I agree with the 9" depth. It appears that most bubblers work properly between 2" and 10" of water.
    The issue I have is transitioning from the coping down to that depth is steep.
    9" of water plus 3" more to top of bond beam is 12". Add another 3" for coping and that first step down off coping is now 15"!!!
    You have to add a chicklet sized step to make that transition safe and more functional. I feel the difference in height between that small step might look/feel akward.
    I'm at 14" of water on my ledge. 10" from coping to first step. 10" more down to ledge and I'm at 14" of water. Then 2 steps down both at 11" each get you to pool depth of 36".
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Eddd's Avatar
    May 2015
    Frisco, TX
    53
    We chose 6"... but not built yet. We'll see. LOL
    About to build an in-ground free-from gunite pool in the back yard (no spa). Currently estimated at 19,000 gallons. Likely going with a SWG.
    Aug 2014
    NJ
    435
    Our sundeck is 8 inches of water and our coping is 2 1/4 inches. Stepping down from th coping to the Sundeck is no problem at all.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Jul 2014
    New England - MA
    310
    Quote Originally Posted by grottoguy View Post
    Thanks grottoguy. What is yor shallow water depth? I'm curious what the riser measurements are on the remaining steps.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    From the surface of my deck, I have my sun ledge as the second step. There is 18 inches of water above it. We love it at that depth. You can drop a couple standard pool loungers in and the water comes right go the seat level. Very small kids like the depth for playing and we have it so that we can block off to keep them from leaving the sun ledge.
    chiefwej
    Aug 2014
    NJ
    435
    I'm not sure I understand your question. Above is a computer generated drawing of our pool. From the sun deck there are no steps down to the pool and the depth ranged from about four feet to seven depending on where they exit the sundeck. On the right of the sun deck there is a bench that connects with the second step of the pool ( the steps are in the cutout on the right).
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I think the OP is talking about a sun shelf in the pool, not a deck above the water level.
    chiefwej
