Results 1 to 7 of 7
Thread: Intex pool splitting
    So,I,have been tracking a leak for 3 days and finally found it tonight. We'll it is 2 small splits right where the pool floor begins to lift from the ground. I have put a patch over it but it is just one of the clear ones with glue.
    I am sure this won't stop the splitting. Is there a way to stop it from splitting more? I was thinking maybe drain and find a good piece of vinyl or an old intex scrap and pvc gluing it down really well.
    Does that sound like it would work?
    Intex ultra frame 22 x52
    intex sand filter and pump
    intex saltwater generator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Intex pool splitting
    Welcome to the forum,
    Whatever you decide to patch with, use the vinyl patch glue. You can buy big tubes of it in patch kits but don't use PVC glue no matter what. I'm not trying to be negative, but the splitting may be impossible to stop.
    Essential Links:
    That's what I was thinking too. That is why I was wondering if a stronger glue would maybe hold better on an actual piece of liner
    30,421
    There is a brand of glue specifically made to patch pools and it has been mentioned on this forum more than one but I can't find it. Someone will see this post and say the brand, I hope.
    An actual piece of liner will be the best hope for getting it stopped.....good luck
    Put your significant info in your sig so we can tell what size pool you have, etc. Draining 5k is a different task than draining 50k.
    Maybe "Boxer" is the brand referred to above.
    hole patch not holding ... can you help?
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Boxer is one, but I have seen it somewhere online in a pint or so sized can.
    Essential Links:
    Casey's Avatar
    SW PA
    10,448
    You need to triple up on the patch, both inside and outside of the pool, with each patch being bigger than the last.
