Thread: Jandy LXi Heater not igniting
    Jun 2015
    Las Vegas
    1
    My Jandy LXi heater won't kick on for the pool or spa. Worked fine a few weeks ago then last week I went to start it and all I got was an electric hum. The whine of the blower didn't kick on. Is it the blower motor or something worse? I don't smell gas so that's good.
    Jun 2012
    western NY
    1,559
    Re: Jandy LXi Heater not igniting
    Did you verify if there is power to the unit? Could as simple as a tripped breaker or someone turned a switch off.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,679
    Verify power and do you get anything on the display when you turn it on?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
