Thread: Keeping the pool clean during winter - I've got lots of dirt
    May 2008
    Central Texas
    60
    Hey everyone, it's "winter" here in Austin, Texas. Which means alternating weeks of 60 degrees and 40 degrees. I'm having a problem with dirt in our pool. Every couple of days we get a ring of dirt around the bottom. Now, since it's closed, I have only been running the pump for an hour a day. So is the dirt a function of the filter not being able to do it's job properly, the fact that I've got a lot of dirt instead of grass near the pool (thanks to 3 large dogs), or something else?
    I vacuumed last weekend and within a few days the dirt was back. I just did the same thing today and backwashed... a bunch of dirt came out for about 30 seconds.
    I also dumped 2 182oz jugs of chlorine in last weekend... I know it's probably not necessary... but since getting the pool clear with the help of the board last summer, I'm kind of obsessed with getting ahead of the algae this year
    Anyway, any thoughts on how to keep my pool a little nicer looking during the winter months would be appreciated.
    Thanks!
    11,000gal, in-ground, concrete, sand filter, 3/4 HP pump, TF-100 Test Kit, Austin Texas
    Oct 2007
    Valrico, FL
    542
    Re: Keeping the pool clean during winter - I've got lots of dirt
    I have a solar cover on my pool and it catches most of the dirt that blows in. Every so often I take the solar cover off and wash it on my drive way.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I am in Fort Worth and right or wrong I have my filter running 4 hours with my Letro-Legend running for 2-hours. The pool is spotless and looks extremely inviting but "the water is only 54ยบ"
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Chappy asked "So is the dirt a function of the filter not being able to do it's job properly, the fact that I've got a lot of dirt instead of grass near the pool (thanks to 3 large dogs), or something else? "
    I'd say both. The dirt has to be "stirred up" to get into suspension for the filter to do it's job, or the dirt has to be pushed toward the main drain (if you have one), to get out of the pool.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Apr 2008
    Central Texas
    326
    I'm just north of Austin and my pool is spotless (and COLD!). I cut back the pump run time from my summer setting of 8 hours per day to around 4 hours per day. My Polaris also runs for an hour each day. I just leave it in the pool all the time and clean the filter bag when required.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    May 2008
    Central Texas
    60
    Interesting. I am going to run the pump for a few more hours a day during the winter to see if I can keep it circulating enough to filter out most of the dirt. It's also a little milky right now as well, not sure what would cause that during this cold weather. Thanks for all the replies.
