Results 1 to 8 of 8
Thread: Bow inside pool between braces
    I purchased a Cornelius 18x33 NBS Solex pool in August 08. When the pool was installed I noticed that one straight side of the Pool on the inside seemed to bow out slightly between the vertical supports. This has worsened and become very noticeable. I contacted Cornelius and sent them pictures as to what the pool was doing. Their reply was with this type of pool without outside support the bow was a normal occurrence and before long the other side of the pool will do the same thing. It was normal and nothing to worry about.
    What do you think? Is Cornelius pulling my leg?
    Thanks
    KingsleyZissou
    30' AG Pool
    48" high
    Jandy Lite 2 Heater
    Pool Power Pak II Pump
    Doughboy Sequel II DE Filter
    30,419
    Re: Bow inside pool between braces
    Welcome to the forum.
    I am not familiar with the construction of Cornelius pools so I cannot definitively answer your question. I would be concerned that it is only on one side so I would not accept that explanation......it doesn't seem to make sense.
    Oct 2007
    Cedar Hill, TN
    251
    Could you post some pictures?
    Some of the members here are professionals, and could tell you if this is normal or not.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    I wouldn't worry about it as long as it's not bowed anymore that what you see in this photo. I have the same pool and this is a picture of the bottom rail that hold your wall.
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    30,419
    After seeing 98's pic, that does make sense to me now and I would think that's not an issue.
    Thanks Gang for your help. This is my first experience with a pool and I had bad visions of 15,000 gallons of water flowing across my yard.
    Here's a picture we took before we covered it for the winter.
    It's 30 degrees out but I want to go swimming brrrrrrr.
    KingsleyZissou
    30' AG Pool
    48" high
    Jandy Lite 2 Heater
    Mar 2007
    Coastalish 'down easter'
    4,160
    All the AG oval pools I've seen do it In case you weren't there when the wall went up - it comes rolled up so it has no rigidity to keep the walls from bowing out between the uprights.
    I wouldn't worry about the pool draining itself into the yard as long as the liner stays whole and the wall doesn't rust out
    Luv& Luk
    -Ted
    South Central NJ
    3,192
    Watch for leaks in the liner. They will cause washout. This stretches the liner further exacerbating the situation. Blow outs happen. 10,000 gallons into the back yard in less than 10 seconds. Glad it wasn't mine.
    Owner of - PoolGuyNJ LLC
