Thread: TFP vs. My Old Chemicals
    IowanPool's Avatar
    May 2015
    Ankeny, IA
    24
    After a slow start this Spring and doing lots of reading on TFP I'm stuck with a dilemma... I bought 70 lbs of stabilized chlorine (pucks and granular). Now that I'm reading about the The use of liquid chlorine what should I do with my old chemicals? Should I use them up this year and switch next year? Other thoughts from folks who have switched?
    Thanks!
    20x36' in-ground vinyl pool. 25.5K Gallons. Sta-Rite Sand Filter. Pentair Ultratemp Heat Pump. Pentair IntelliFlo variable speed pump. Tri-Chlor Feeder. Automatic Cover. Taylor K-2600 test kit. Pool owner since 2013.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: TFP vs. My Old Chemicals
    If you keep them dry, the pucks will outlive you. So save 'em. As you lose CYA to splashout and backwash or because of torrential rains, you can raise it back up with pucks. The powder will be good to raise FC and chlorinate when you refill next spring after winterizing.
    IowanPool's Avatar
    May 2015
    Ankeny, IA
    24
    Thanks again! I'll bump it up right before start time.
    Thanks!
