Thread: Doughboy AGP costs
    Doughboy AGP costs
    I am looking into a new AGP for this spring/summer, in Chicago suburbs. I pretty sure i am going for Doughboy because they specifically make AGPs that can be buried and I will be buring mine about 1/2 in ground. Want to know if anyone has purchased this pool and if so what they paid. I am looking at the oval 12 ft by either 22 or 24 maybe 26 feet. thanks.
    30k gallon inground with vinyl liner
    Hayward cartridge filter
    Southcentral PA
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    Re: Doughboy AGP costs
    Hi amp. Last May, we had a 32 x 16 Doughboy installed and buried 3 feet with a 7' deep end. The entire purchase/install (less plumbing the waste line to the city piping, which was required) ran us about $10K, which included the price of the best/thickest expandable liner (The install/bury was $3200 of the $10K and well worth it). We only opted for one return and later had to install a 2nd return ourselves, as well as hard-plumb the entire pool, because we didn't like the vacuum-cleaner type hoses. Doughboy allows a full bury (I think 6" must remain above ground) with still a full warranty. We want to do step-up decking around the entire pool, and so just did the 3' bury. The installer stressed to us to not ever, ever drain the pool - the walls will collapse. I'm assuming that we could probably drain just long enough to replace the liner, if necessary, and then refill immediately. I don't know what our water table is, but that plays a role in it. Hope this helps.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Thank you very much for the great info. This really gives me an idea of what I will be dealing with. Because of backyard size and easement I cannot get any pool wider than 12', but length is unlimited looking at somewhere between 22 and 26. Also my yard is a hill so one end of the pool will be at grade and buried into the hill so that only about 40-50% of the pool will be fully buried. Because of that don't expect any issues with dig. Thanks again for info.
    Southcentral PA
