Thread: replacing (installing) new hayward CL200
    how would I know if the pipes are not only screwed to the chlorinator but are they also glued? I don't want to create yet another problem by trying to take this off with a wrench if the pipes need to be cut.
    dianne in Bucks County, Penna
    44,000 gallon bare concrete inground pool
    dolphin diagnostic pool cleaner
    pac-fab 48 sq ft. d.e filter
    Hayward CL200 chlorine feeder
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: replacing (installing) new hayward CL200
    I think a picture is needed on this. Unless someone is more familiar with your equipment than I am.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The should not be glued as the installation is just pressure fitting threaded unions, but builders and homeowners do some odd things to install or fix problems so it could be anything. You won't know until you try to unscrew the unions.
    Isolated Spa - 345 Gallons
    the fitting is threaded onto the chlorinator but it appears that the other end of the connection is glued to the 1 1/2" pipe
