Thread: Cleaning an impeller
    Jun 2015
    Flemington New Jersey
    6
    How do you clean debris from a Hayward power flo matrix pump for an above ground pool?
    15x30 oval above ground pool; hayward 1 hp power flow matrix pump; sand filter
    30,426
    Re: Cleaning an impeller
    Power off, you should be able to reach into the intake with your fingers and pull out any debris.
    May 2012
    Montville NJ
    545
    Do you have debris in the pump itself? Is it the sort of thing that you can remove the pump/motor assembly and then flush it out with a hose?
    If not you have to first remove the strainer. Take the clear top off and take out the strainer basket. There is a C clip inside the strainer housing that holds the strainer body to the pump inlet. Remove this C clip by pulling up. You should then be able to slide the strainer housing off.
    If you have one of the newer power flows, there is a button you can press to rotate the discharge from horizontal to vertical. This may help in getting in there to remove whatever is blocking the impeller.
    If you still cant get out the blockage, you will see 8 screws that you can take out to remove the pump cover and expose the impeller.
    If you do that last step, be careful not to mess with the seal that is on the motor shaft - unless you want to buy a new one that is.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2015
    6
    Thank you for the replies. Is there a way to plug the return so that water does not run out when I open the pump lid? I can plug the skimmer so that water doesn't run out from there.
    30,426
    Depending on the size of your return opening, (and you may need some help) you can get someone to hold a bowl over the water side of the return and seal it fairly well.
    Is the opening the correct size to partially insert something like a ping pong ball?
