Results 1 to 12 of 12
Thread: Lots of rain... Now to balance pool chemistry!
    May 2015
    Nacogdoches texas
    21
    We just received a lot of rain and now my pool is kind of cloudy. Here are the numbers I got from my k2006 kit this morning. Can someone help me get it back on track? I have a 22' x 52" intex above ground pool with SWG. thanks!!!
    fc: 2.5
    cc: 0.5
    ph: 8.0
    ta: 130
    cya: 45
    Intex 22'x52" above ground pool with cartridge filter and Intex SWG
    k2006 test kit
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Re: Lots of rain... Now to balance pool chemistry!
    Are you familiar with the Pool Math page?
    http://www.troublefreepool.com/calc.html
    Plug in your numbers and it will tell you exactly what to do. You want your chlorine above 4ppm and your ph between 7.5 and 7.8.
    Just noticed your SWG, you want to raise your CYA as well.
    And if it's cloudy, you might just go ahead and SLAM.
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You will need to lower your PH to around 7.2- 7.4. You also need chlorine to raise FC level.
    Your CYA is low for having a SWG, but we can address that last. We want to get the pool water clear first. Your CYA is at a good number to SLAM should you need to.
    Have you done a OLCT to see what your overnight loss it?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Nacogdoches texas
    21
    I ran the numbers in pool math and it says to add stabilizer and muratic acid. It says to add bleach also for chlorine- but since I am running a SWG should I just do a boost cycle? Or do I add the bleach? Thanks so much!!!
    k2006 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You have pretty high TA, so lowering pH will help bring that down. pH will pop back up in a day or two. I get that your pool is approximately 11,000 gallons. A quart of 31.45% Muriatic Acid should get pH down to a good spot.
    If things look cloudy, you want the FC up fast, just in case things are growing in there. I wouldn't wait for the SWG to catch up. Half a jug of plain clorox will boost that and the SWG should be able to keep it there.
    You'll also want to think about raising CYA some. That will help the SWG keep up with the sunlight losses. If you go to the last row in poolmath and select the surface and SWG and TFP, it will show you recommended target levels for all your chemistry.
    May 2015
    Nacogdoches texas
    21
    Awesome!!! Thank you all soooo much!!!!
    k2006 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    We use bleach here. The SWG is designed to help maintain you FC level once it is at level. Using the boot cycle will not raise it enough. Don't add the stablizer yet. Ad the muratic to bring down your PH.
    Step 1 add bleach to raise FC to 4-5ppm
    Step 2 1 hour later add muratic acid to lower PH 7.2-7.4
    Step 3 re test FC and PH an hour later and post the numbers.
    Since your water is cloudy, you will likely have to do a short SLAM. I'd you raise CYA now it will require you to use more bleach to clear the pool water.
    Lisa
    May 2015
    Nacogdoches texas
    21
    Ok so I added the muratic acid and bleach on Friday. Yesterday my chlorine was 5.5, ph 7.4, and Ta was 130. Pool is still somewhat cloudy- should I just give it a few more days to clear up or do I need to add something else?
    k2006 test kit
    Richard320's Avatar
    Jan 2010
    18,967
    I'd give it another blast of bleach. And run an overnight loss test tonight. If it fails, you've got the beginnings of an algae bloom. Pool School - Perform the Overnight FC Loss Test (OCLT)
    May 2015
    Nacogdoches texas
    21
    What should my chlorine levels be using the SWG during slam? I think normal is 3-5 and mine is 5.5... Trying to figure out how much more bleach to add. Thanks!
    k2006 test kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your FC level should be the SLAM level recommendation from the chlorine/Cya chart.
    You should not use your SWG during the SLAM. You are just using cell life on the SWG unit.
    Lisa
    30,403
    DO NOT use the SWG during the SLAM!
