Thread: Pool store advice/errors need help
    Been away from my pool for a year. Daughter and grandsons in charge. After first swim party since my return pool became cloudy/slight green tinge. I brushed, vacuumed and raised chlorine somewhat for 2 days--no better. First store told me my CYA was 150. I left. I got 75-95, old eyes not so good. Second store said 95 and told me that was ok--continuing to use pucks fine--but must buy/use phosfree for 3 days and then perfect weekly program. Cost $100++. I left. #'s were FC 2ppm, pH 7.6, TA 90, CH 150 CYA 95, phosphates 800. I added 6 pints 8.5% bleach FC up to 13.5 but still too cloudy. I'm in Sacramento so even a partial drain/refill would result in 10 year sentence, minimum. Superchlorinate? How much should I add if so. Any ideas appreciated.
    SACRAMENTO, CA
    15,000 GAL. IG Plaster Pool/Spa w/waterfall size 16' x 30' surface 422 sq ft
    3/4 h.p. pump 70 g.p.m. @ 60 t.d.h.
    turn rate 3.45 hrs
    320 sq.ft. cartridge filter
    Test kit Taylor k-2006 fas-dpd chlorine
    Skitch's Avatar
    May 2015
    Athens, Georgia
    112
    Re: Pool store advice/errors need help
    If you're confident in that CYA reading, you'll need to take your free chlorine up to nearly 40ppm.
    Pool School - Chlorine / CYA Chart
    Pool Math will tell you how much bleach to add.
    http://www.troublefreepool.com/calc.html
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Your chlorine is too low for your CYA level and algae is beginning to grow.
    Phosfree is not the answer, as SLAM is. Plus, the guy who told you 95 is good and to keep using tabs is either ill informed of lying.
    Read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end. The problem you will have is it will take massive amounts of chlorine to kill the algae with CYA that high.
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    The water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    The cure is bleach and brushing and time.
    You've complicated matters with the phosfree. I'm actually rather startled that you didn't report that the water is now milky. Did you read the instructions the manufacturer provides? They even say algae must be treated first.
    For DE & Cartridge Filters: Do not add more than 1.5L (48oz) at a time. If more than 1.5L (48oz) is needed to treat, be sure to clean or backwash the filter between treatments.
    Important: Algae must be treated prior to testing and lowering phosphates. Chlorine must be under 5ppm before testing phosphates.
    http://naturalchemistry.com/en/pool-...tail/phosfree/
    After the stuff has had time to collect and goop up your filter cartridge, you need to clean it off. And then SLAM. Take the FC way up. At 95 CYA, it's going to be an unbelievable 37 FC.
    Call the water company. They may allow a one-time swimming pool fill without penalties, as long as you arrange it. It costs nothing to call and ask. If you can dilute the pool, even down to 60 CYA, it will help a lot.
    Thanks for advice, I didn't buy or use the phosfree--don't know much but knew better than that. I'll start slamming today.
    SACRAMENTO, CA
    turn rate 3.45 hrs
    Jul 2013
    North Canton, OH
    192
    My pool store tested phosphates during an algae bloom and said they were 1500. Per TFPC advice I did not treat the phosphates and instead did a SLAM. Pool is good now. I asked the pool store to test phosphates again when I went in for supplies. This time they said 300 and that it was fine. I pointed out that they had told me 1500 the week before. This person who I have found to be one of the best at this store (she was also the one that said to stop using granular because I was driving my CYA too high) asked if I had algae when they tested before and I said yes. She told me algae interferes with the phosphate test and that in the middle of a bloom I should not worry about anything but chlorine until the bloom was gone.
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
