Thread: Ecostar vs Intelliflo: High Head Application
    Oct 2011
    6
    Hi guys
    Long time service tech here. I have an inground spa on service that has the equipment 100' away and 3-5 feet below water level. It has a Pentair 200 sq ft single cartridge filter (new) and had an old 3HP Whisperflo pump that recently burned out. The system has always run around 30 psi even with a new cartridge and gave acceptable bubbles from the returns. (No booster or blower).
    I've had good luck with the Ecostar pumps and figured that it should equal or exceed the old WF but after installing one I have very little flow (32 psi @ 3450 rpm). The pump basket is full, no cavitation, runs smooth, just not putting out like the old WF>
    Is the WF a better high head pump than the Ecostar both being the highest powered available? I hope I didn't make a costly (to me) mistake here.
    Appreciate any input!
    bob
    Jun 2014
    15,130
    Re: Ecostar vs Intelliflo: High Head Application
    Hello and Bob! I see you haven't received a reply yet on your post. Our apologies. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    38,290
    With no other changes to the plumbing setup besides replacing the pump, if the filter pressure is the same, then the flow rate must be the same.
    Oct 2011
    6
    But the replacement pump is different! Was old 3HP single speed Wflo, new one is Ecostar xx HP?
    thx
    bob
    38,290
    Does not matter. It is the flow rate that causes the pressure in the filter.
    So if the pressure in the filters the same then the flowrate must be the same.
