Thread: FC & CC Test
    May 2014
    Merrimac, MA
    47
    FC & CC Test
    I've noticed that if I leave my completed test sitting for a bit that eventually it will have a pinkish hue. So I do the cc test and the water doesn't change color...not immediately, but after several minutes it will. Is this normal, should I be waiting before recording my results?
    26,700 Gal., 18x36 IG pool with Vinyl. 1HP Hayward Super Pump; Hayward DE3620 Filter; Hayward SAS; TFT-100 test kit; Dolphin Atlantis Cleaner.
    May 2015
    River Falls, WI
    124
    Re: FC & CC Test
    That's normal. You do the CC test immediately after the FC test. No waiting.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Re: FC & CC Test
    Hi CLW, yes it is known that if you leave the test for a while after it has gone clear it will turn pink again. the test should be completed quickly and then the cc test immediately afterwards without any break in between. best wishes
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    May 2014
    Merrimac, MA
    47
    Re: FC & CC Test
    Awesome, thanks guys!
