Thread: leak in my 15000 gallon above ground pool!! HELP!!
    Jun 2015
    MS
    1
    My pool started leaking last yr around the hose that goes into the pool. Got that fixed and now now it is leaking from the bottom of the pool until it gets about 3/4 empty then stops!! What is going on?? It's coming out from under the side where the pump hose is at, but it's not the hose bc everything is unhooked!! HELP PLEASE!!
    You can't really see the ground wet right beside the base of the pool on the ground. Its staying wet but not like it was. I do not know how to check for the leak other than drain it?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: leak in my 15000 gallon above ground pool!! HELP!!
    Examine the pool and any fittings right at the height where it stops leaking. That's where your leak is at. Your pool is telling you where the leak is, based on where it stops leaking. Might be a spot in the liner that needs to be patched.
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,404
    Can you post some pictures of the problem area?
    Love TFP? Become a
    TFP Supporter!
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Interested in the answers for this also, I have the same thing going on. The ground around the pool is wet so I'm guessing it's at the bottom of the pool like this one is. It seems that maybe the pressure isn't enough to make it leak with the pool partially drained on the OP's pool?
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
