Results 1 to 9 of 9
Thread: evil Frog?
    Jul 2013
    North Canton, OH
    192
    evil Frog?
    I thought I would start a new thread to ask this question. In my thread about green tinted water, SW commented "pull that frog system out pronto if you haven't already." I have seen a couple of other comments on the forums about the "evil" Frog systems. What is bad about them?
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: evil Frog?
    The copper the frog puts in the water turning the water and blond hair green.
    Support the site
    Jul 2013
    North Canton, OH
    192
    Re: evil Frog?
    would it be OK to use the Frog for slow chlorine addition with their BacPacs and leave the mineral cartridge out?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: evil Frog?
    Quote Originally Posted by bkfamily1 View Post
    The chlorine is trichlor, which raises CYA. It's just pucks in a fancy feeder.
    http://www.kellysolutions.com/erenew...8_13_32_PM.pdf
    Jul 2013
    North Canton, OH
    192
    Re: evil Frog?
    Amazing what you can learn from an MSDS!
    So is there a good method for slow "continuous" chlorine addition? I could do metering pumps and injectors with liquid like in an industrial setting, but that seems a bit over the top. I assume the typical basic in-line chlorinator using pucks is the same issue as the BacPacs. I like the gradual addition since I do not have to worry about the pool as much if a period of time goes by without anyone in the pool. Once I get the addition rate correct, it stays good when not in use.
    May 2014
    Franklin, NC
    9,184
    Re: evil Frog?
    Injection pumps or a Salt Water Chlorine Generator are your two real choices. Figure a $1,000 if you wan to go salt or probably $400 or so to go with a Stenner Pump
    Both are really just nice to have. Many folks just go out with thier morning coffee an pour in their daily dose of chlorine. After a few weeks of testing you will basically know what your pool needs and can add it almost automatically. Mine uses about 56 ounces of 8.25% bleach a day.
    Support the site
    Jul 2013
    North Canton, OH
    192
    Re: evil Frog?
    We did not go with swg because of concerns of corrosion of the rails of the auto cover which are embedded in the concrete below the coping. Is that a real concern?
    May 2014
    Franklin, NC
    9,184
    Re: evil Frog?
    Any time you have water and metal you will have corrosion. The salt levels in a pool are extremely low, so most think it is a non issue. But, there are pool builders and manufacturers who are dead set against it. I'll let others who have a swg chime in.
    Oh, I really like my Stenner Pump
    Support the site
    Jul 2013
    North Canton, OH
    192
    Re: evil Frog?
    I will definitely look into the Stenner - thanks for the suggestion
