Results 1 to 8 of 8
Thread: Chronic Calcium Scaling
    I don't have this issue, but stumbled upon this product for those that do-
    http://www.4deepblue.com/
    I know nothing of it, but it looked interesting. I didn't know where to post it, so I figured here would be good and someone can move it if it's better suited elsewhere
    Mar 2007
    Knippa, Texas
    289
    I may be mistaken, but to me it looks like another way to separate hapless pool owners from their hard-earned money. . .
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Guest
    This company says on their website:
    "The MPULSE 3000® treats pool water by applying high frequency, low voltage impulses directly to the water to change the calcium bicarbonate form (hard crystals) to a carbonate form (soft crystals) at the molecular level. In the carbonate state, the calcium becomes easier to manage on pool surfaces."
    I say SNAKE OIL!
    Calcium bicarbonate can ONLY exisit in solution. In solid form (scale or 'crystals' as they call it) it will be calcium carbonate!
    Ca(HCO3)2(aq) → CO2(g) + H2O(l) + CaCO3(s).
    There is no such thing as crystals of calcium bicarbonate! Also, all chemical reactions take place at the 'molecular level'. Their claims are all pseudoscience and doublespeak!
    On another part of their website they talk about the unit forming the aragonite form of calcium carbonate instead of the calcite form. Precipitation of calcium carbonate will form the calcite form unless temperature are over about 104 deg F, and a higher level of magnesium hardness in the water than calcium hardness. Since their unit does not change the chemical makeup of the water perhaps it is only a heater?
    SNAKE OIL!SNAKE OIL!SNAKE OIL!SNAKE OIL!SNAKE OIL!
    check out this link that debunks this and some other claims made for useless water treatments (including the EcoSmarte ionizer)!
    30,403
    I think waterbear just moved it to the "Uh-oh!" forum
    Dang it, waterbear. I ordered seven of those things this morning!........."Uh-oh!"
    And now we know
    Arizona
    924
    I'd be skeptical too. Wonder what the price is for one.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    "If something looks too good to be true, it probably is!"
    Can't remember who said this, besides my mother!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Since calcium bicarbonate is soluble in water at around 16.6 g/100ml which is 166,000 mg/l (ppm). In other words, in pools, calcium bicarbonate does not even exist. It is instead separate calcium and bicarbonate ions. There is a calcium bicarbonate ion pair, CaHCO3+, but it is very low in concentration (200 times less than calcium and bicarbonate ions). Just throwing some more fuel to the fire.
