Results 1 to 8 of 8
Thread: Am I over thinking this
    Jun 2015
    Tupelo Ms
    18
    I just purchased a 16x48 Intex pool. My question is which like the title says I am probably way over thinking this, on a 16' pool it has 8' radius I need to go out an extra foot, I am going to be using foam under the pool do I go out with the foam over the pavers or all the way out to the whole radius that I leveled out. Please forgive my ignorance I tend to over think stuff.
    Jul 2014
    Hope Mills, NC
    567
    Re: Am I over thinking this
    I would think that a 16' diameter circle would have an 8' radius, as radius is one half of diameter...but that's just me.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jun 2015
    Tupelo Ms
    18
    Yes it has a 8' radius mistyped that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    The pictures I've seen have the foam cut out around the pavers so it's all at the same height.
    Jun 2014
    15,083
    I believe the intent of the foam is simply to provide that buffer (cushion) required to protect the bottom of your liner and make it more comfortable for the users. If you go outside of the bottom edge of your pool, it may not hurt anything, but it may get in the way of the poles, pavers, or equipment that you have. Just a thought. Other Intex users may have other thoughts. Have a great day!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    I'd notch it out for the pavers myself.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Check out my build in my signature,
    allot of good photos and details that might give you some ideas. All are correct ... I cut mine as I am leaving my pool up year round and didn't want to see the insulation. I will be doing some landscaping around the pool soon. Good Luck
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jun 2015
    Tupelo Ms
    18
    Thanks for the help that looks great. Does the pool liner not touch the paver stones I am going to put mine up like you did yours.
