Thread: Helping a friend with SWG
    May 2012
    Lexington, SC
    132
    I'm potentially going to be going to a friend's house to test her water and introduce her to TFP. I've got the macdaddy kit (can't remember the number of it, you know what I'm talking about though!) so I can pretty much show her how to test it all. I don't have a SWG, though, so I'm trying to easily find out the differences, if any, in how I test her water. I did find these recommendations for where she should be at in Pool School:
    To summarize:
    FC 4-6 ppm
    PH 7.5-7.8
    TA 60-80
    CH
    50-300 for vinyl
    220-320 for fiberglass
    250-350 for plaster
    CYA 70-80
    Salt 200-400 ppm ABOVE recommended optimum level
    Borates 30-50 ppm (optional)
    What I'm wondering: Do I test her chlorine levels the same way as I do mine, even though she's got SWG? She's got algae now and just spent loads at the pool store (yuck). Does she SLAM the same way for SWG as I do? She's probably got shock of some sort in her pool now, so figures will be off anyway, but I thought I could potentially at least check where her FC is and check out her CYA. I know the pH won't be a good read if she's at shock level. Any info you can give so I can help her out and get her on TFP would be awesome!
    13,500 gallons
    Sand filter
    IG
    TF-100
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,870
    Re: Helping a friend with SWG
    Hi from cola area.
    Yes test the same way as always.
    SLAM the same way you would for non SWG BUT......turn the SWG off and use chlorine. This will help save the salt cell life. But, if she can't test and redose very frequently the SWG COULD be left on to help maintain high FC.
    I usually try to keep mine off.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    May 2012
    Lexington, SC
    132
    Awesome! Thanks so much Aimee! I did read about adding chlorine manually to SLAM. I wanted to make sure I understand her system so I don't misinform her. Hoping I can bring her over here to at least read Pool School and join the forum.
    Stay cool! Ugh...this weather! Thank God for pools!
    13,500 gallons
    Sand filter
    IG
    TF-100
