Results 1 to 8 of 8
Thread: No CYA - Low FC and a CLOUDY POOL!
    May 2015
    Northern Indiana
    6
    This is our 2nd summer -we are new pool owners, and last year things went smoothly.
    This year . . . .
    Today's testing shows:
    FC 1.5 ppm
    CCl 0.5 ppm
    Total Alkalinity - 220 ppm total alk. as Cal Carb.
    Ca Hardness - 230 ppm as Cal Carb.
    pH 7.4.
    Cy Acid - too low to be measured
    I am confused about the shocking. . .
    1. Do I really want to add enough Chlorine to get to FC=24 ppm. . .
    2. What is my best source for Chlorine - we bought some powder kind - it is Calcium Hypochlorite (and I see on this site that this could inc. my Calcium Hardness. . . )
    any HELP very! appreciated
    Also
    New to Pools - in Northern Indiana
    In Ground - Fiberglass - 17,200 gallons (Thursday Pool)
    Pentair "clean & clear" Cartridge Filter; Pentair "SuperFlo" pump;
    SWG - Hayward Turbo Cell T-CELL-9; Hayward "Aqua Rite" Salt Chlorine Generator
    38,360
    Re: No CYA - Low FC and a CLOUDY POOL!
    Welcome to TFP!!!
    1. No, because you did not report a CYA value which determines the required FC shock level from the FC/CYA Chart.
    2. Liquid chlorine / bleach because it does not have the side-effects of the solid chlorine. The cal-hypo will add CH (which you do not really need any more) and can cause cloudy water.
    Where did you get those test results? I am suspicious that they are not from one of the Recommended Test Kits which is required to follow the ShockLevelAndMAINTAIN Process.
    Have you discovered Pool School yet? Start with these so we are sure we are speaking the same language:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jun 2014
    15,189
    Welcome Barbie J! You will learn a ton of stuff here in a very short amount of time. Difference between what you learn here and what you learned in other places is that the knowledge you gain here will make your summers more enjoyable.
    To echo Jason's comment above, we highly encourage you to get the proper test set (i.e. TF-100) link below. You will be amazed at how well it helps you manage your water.
    Stick around and ask all the questions you need. Lots of people here to assist. Nice to have you with us.
    Apr 2015
    Quinlan, tx
    811
    Yes. Everyone is super nice and helpful!!
    26,000 IG, pebble tec, flagstone, pentair Triton II TR100 sand filter & VS+SVRS 3hp multi-speed pump, Intellichlor IC-40 SWG, Pentair Booster Cleaner, spillover spa, waterfall, Taylor K-2006 testkit
    [It is better to know how to learn, than to know. - Dr. Seuss[/I]
    May 2015
    Northern Indiana
    6
    I'm using the taylor 2006 kit recommended on this site...
    should i I keep adding CYA - then once it's measurable add chlorine - or just keep adding both?
    38,360
    You need to add FC at least daily to keep it above the minimum needed.
    When did you add CYA and how much? Did you have a CYA target in mind? IT can take up to a week to show up on tests.
    May 2015
    Northern Indiana
    6
    Thanks for letting me know it can take that long. . . I think the pool math thing said to add 172 oz CYA - so far we have added a 64 oz bottle of 98% cya - two times (total 128 oz) - -I will wait for a while before adding more so I can give it time to show up.
    Our FC was up some yesterday - so we added Bleach. . . hope we are going in the right direction. . .
    Thanks to all for the help!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Did you add liquid or granular stabilizer? How did you add it?
    Ok, 128oz of stabilizer starting at 0 will give you 56ppm of CYA.
    Use the Chlorine CYA Chart to determine what your chlorine level should be and always keep it at or slightly above target. Never let it drop below the minimum level or algae will start growing. Your cloudy water is the beginning sign of an algae bloom. It is very important to get your chlorine level up to target immediately before your pool turns green.
    Use Pool School - PoolMath to determine how much chlorine/bleach to add. At the bottom of poolmath is a tool where you can see the effects of adding chemicals, which is how I determined how many ppm 128oz of CYA added to your pool.
