Thread: New Pool Owner- Calcium Build Up
    Jun 2015
    Panama
    1
    Call me the rookie of the group but we recently bought a 22ft salt water pool its has been up for 2 weeks and levels have been what the manual considers normal but getting extreme calcium build up. The pool is getting cloudy and even starting to plug up the pump system and when we brush the plastic cover for the pump with vinegar it instantly fizzes. What do we need to do to correct this issue. i hate to just start dumping in chemicals that may harm my family.
    Above Ground-- Intex- 22ft Vinyl Saltwater Pool
    38,275
    Re: New Pool Owner- Calcium Build Up
    Welcome to TFP!!!
    As always, we need test results in order to offer relevant advice.
    I am unclear why there is buildup on top of the pump? Shouldn't that stay dry?
    Feb 2014
    Jersey side of Philadelphia
    93
    I wonder if you need to backwash your pump? Could it be clogged up?
    And, get those test results in!
    24,500 Gallon (640 SF) Inground Gunite Salt Water Pool w/ Diamond Brite Midnight Blue Plaster. Pentair IC 40 Chlorine Generating System. Hayward 60 DE Filter. Jandy Aqualink Remote System. Polaris 360 Automatic Pool Cleaner. 50 SF Spa with waterfall feature
    Hayward 440,000 BTU Heater. Two Colorlogic LED pool lights.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Calcium coming out of the water indicates a serious pH problem.
